LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Accessing Voicemail on LG KS360?
I can't access the options on Voicemail using an LG KS360 phone - it won't let me type/press the numbers to access the different options.
  • Emspark May 10, 2009
    Wenever i get a new voicemail it says i need a nuber n i dont no wat that number iss :s please help mee !!!!!!!!!!!
Anonymous
Level 2:
  • Expert 122 Answers
  • Posted on Apr 26, 2009
Anonymous
Expert
Level 2:
Answers
122
Questions
0
Helped
45875
Points
451
When you press numbers do they appear on screen as if you had pressed?
Is it that when you press a key your voicemail just does not respond to the option number you pressed?
If the answer is yes to these it sounds like you have turned off DTMF tones. If it is off, key presses look like they work but actually the phone is blocking the tone for that button from being sent down your line. People sometimes turn off by mistake or to stop their mobile number being visible when calling someone. If you look in menu and make sure DTMF tones are ON it should solve your problem? Hope that helps?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1061
Points
12
I had the same problem and I read the post from
Z1G ZA9, and that solved my problem. To give you step by step, because i had to search thru the fone and find the DTMF option, so here it is, and again a big thanks to Z1G ZA9. 1.press menu button 2.select "settings" 3.select "call" 4.scroll to bottom and select "send dtmf tones" and make sure they are on.
Ervin Banks
Level 2:
  • Expert 107 Answers
  • Posted on Jul 14, 2009
Ervin Banks
Expert
Level 2:
Answers
107
Questions
0
Helped
25750
Points
354
To access your voicemail, you have to hold down 1 on the dialing pad, and then you must enter your phone number in the bar on the bottom. Then it will call your voicemail, and then you have to press #, and then you must enter your security code, which, by default, is 9999.
How do I change the number of rings on my LG classic flip phone
In a normal call, it will carry on ringing until you answer. If you have a message service set by your teleco, there is often a setting in messaging set up voice prompts, but they are all slightly different. You get to them by accessing voicemail. On mine it say option 5 says "to alter your voice messaging system, press 5'. Contact your telco, they may be able to do it for you.
How do I set up voice mail
How to record a voicemail
    1)Call your Voicemail access number, or press its corresponding shortcut key (usually the number "1").
    2)Press the key corresponding to "set your voicemail greeting" or "Set up your voicemail."
    3)Decide whether you want to use an automated greeting, which usually gives out your number and advises callers that you're not available.
    4)Follow the prompts to record and save your greeting.
How to Record Voicemail Message on LG Phones
How do I get messages off my voicemail
cell phone voice mail is done by the network provider . They will have an access phone number like for example telstra in austrailia uses 101 optus in australia uses 321 once you are in the voice mail it tells you the options press (whatever number) for delete message.
contact or look up on the phone network providers web site what this voice mail phone number is.
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 • Cell Phones
1helpful
I AM NOT CELLPHONE SAVVY ! I have an LG CG225. If someone is calling me and I do not answer and they want to leave a message, what do I need to do? create a voicemail box so they can leave a message? ...
Issues of accessing/setting up VM on your mobile or Inquiries on accessing your VM using your mobile phone?
I can help you w/that.there are 3 ways on accessing your VM via your mobile phone:
1st:
Long press the number 1 key on your phone's keypad then it'll dial your VM number and would ask for a PIN if PIN is setup.
Follow recording instructions or voice prompts and key presses until you get to hear your voice messages.
2nd:
For some mobile phone service providers,dialing your own mobile number automatically transfers you to your VM.again,if PIN is set up?it'll ask you to enter it,if not it'll automatically proceed to your VM.
Follow recording instructions or voice prompts as well as correct key presses until you hear your voice messages.
3rd:
Almost all mobile phone service providers has a so called "Voice mail Access Number"
This number can be dialled and goes straight to VM.
Voice prompts might ask you to enter your mobile number following the star key or pound sign on your mobilephone keypad.
Voice prompts might also ask you to enter your VM PIN(if seup).
Just follow Voice prompts and you're good to go.
Hope this helps.
Thanks,
FixerDelta
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
When some one calls and leave a message on my lg shine, i am unable to see the call in my call log
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.lge.com/us/mobile-phones/LG-CU720-Red.jsp
Page 46 in your manual: there is more info about messaging here.
Voicemail Menu 2.8
This menu provides you with a quick way of
accessing your voice mailbox (if provided by
your network).
Before using this feature, you must enter the
voice server number obtained from your service
provider.
This may already be available; to check the
voicemail, press and hold the key.
When new voicemail is received, the symbol
will be displayed on the screen.
n Note
Please check with your network service provider
for details of their service in order to configure
the handset accordingly.
Hope this helps, let me know if I can do anything else for you.
JimmyC
6helpful
5answers
Unlocking my phone
I was beginning to think there was no one else from the UK on here :) lol
Here goes, beware its complicated and you can mess up your phone :)
This works without uploading anything to the phone. Just follow the instructions carefully.
You will need 4 bits of software to perform the unlock - get them all now
Download the USB flash loader driver here go the the download USB driver section and find the KS360 United Kingdom Driver.
http://uk.lgmobile.com/web/web.product.manualSoftwareRF.laf
Download the Orange Firmware here (it doesn't matter if you are onOrange or not - it does not get uploaded to the phone, it is justrequired to make the following software work).
http://ks360.assembla.com/wiki/show/ks360/Liens_LG
Download the Extract program here
http://www.pb4kn.co.uk/extract.zip
Download the LG Utils zip file at the top of the list here
http://www.assembla.com/spaces/ks360/documents?c=documents.updated_at&d=down&page=1
You will also need the USB cable which came with the phone - but don't plug it in yet.
Youshould also make sure you have saved all your phone numbers just incase - I have carried this out several times without any problems, butyou can never be too careful.
Follow these instructions very carefully:
1. Install the USB flash loader software (contained in a folder in the first download above)
2. Switch off the phone and leave it off. Do not switch it on until you complete step 14.
3. Plug the USB cable in the computer and phone - wait for it to install all the drivers loaded at step 1
4. Unplug the phone and leave it switched off
5. Create a new folder on your computer (I suggest c:ks360)
6. Double click the Orange Firmware cab file downloaded earlier
7.Select all the files in the cab file. Copy and paste them in the folderc:ks360 - you will need to click save file a number of times.
8. Unzip and run the extract program downloaded earlier
o Type c:ks360Inf_WebDnld.dll and press enter
o Type c:ks360V10G.wdb and press enter
o Type V10G_04 and press enter
o Press enter (and wait a few moments)
9. In the folder c:ks360, some new files will have appeared. Rename KS360AT-XX-V10x-ORG-XXX-SEP-23-2008_slb.flb to KS360.flb
10. Extract all the files from the LG Utils zip file downloaded earlier
11. Run KS360-Utils-EN.exe and choose option N
o type .USB1 and press enter
o Type c:ks360ks360.flb and press enter
o Type STATIC_EEP (get ready to connect the phone)
o Press enter then within 1-2 seconds, connect the phone (still switched off) (timing is critical!)
12. If successful, a new file called STATIC_EEP will appear in the folder where KS360-Utils-EN.exe was unzipped
13. Copy STATIC_EEP to the c:ks360 folder
14. Run KS360-Utils-EN.exe again and select option O and press enter
o Type c:ks360STATIC_EEP and press enter
o The unlock code appears - write it down and close the program.
o (If you get an error message, repeat steps 11-14 - the timing at step 11 is critical to this working)
Now you can unplug the phone and switch it back on
1. Enter the following number (as if you were dialing a phone number): 2945#*71001#
2.When prompted for a password, enter the number you wrote down in step14, press OK, restart the phone......SUCCESS!! Your phone is nowunlocked
1helpful
Accessing voicemail from outside company
Call in your office phone number. When AA picks up press *7. Follow the login instructions.
Cheers
20helpful
3answers
Would like to change voicemail message in phone
-Dial into voicemail
-Enter password to access system
-Press button for Greetings or Administrative Options menu
-Choose type of greeting
-Press button to change it and record new greeting
-Listen to new greeting and press button to confirm
-Exit system
May 02, 2008 • Cell Phones
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
