Question about Canon PowerShot A530 Digital Camera
Having trouble... the flash does not work sometimes, but other times it does. Sometimes it won't work for months, and then it does. Today I tried taking pictures and all I heard was a clicking noise where the flash is. What could be the problem, and is there a resolution?
  • agrawat Nov 13, 2007
    I have canon power shot 530. Sometimes flash works fine but sometimes it doesn't. Even for new batterly it shows batterly low signal and i can't take snaps with flash. though without flash i can click many photos without replacing batterly.
    Second problem is, its diafram doesn't open completely. i need to manully make it open.
  • melkorbol Dec 01, 2007
    I have the exact same issue with this camera.
    The flash light just blinks and it never takes the picture. Some times when I turn it off then on it works, and some times it doesn't. Any suggestions, am I doing something wrong?
    Genius:
  • 2,985 Answers
This sounds like to short or a capacitor failure. The likely cost of repair if at all possible will not a economicx. Best to write it off.
Posted on Sep 28, 2007
SOURCE:
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Nov 30, 2016 | Pride Health & Beauty
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
Caller Id blocking
There are no lines available. Have someone test dialtone on all your lines.
Jun 24, 2010 | Avaya 5400 Series 5410 Phone
Acer laptop problem: Hard disk/motherboard problem
Try 2 things....1) replace the IDE controller cord or the SATA cord whichever applies. If this doesn't fix the prob try downloading latest mobo updates as well as any Acer updates for your specific model. Let me know if any of this works.
Thx
Jul 31, 2009 | Computers & Internet
Turn on of unit sometimes does not light lamp. Red/Green flashing light, then turns on the next time. (Using button on unit) When using remote, can sometimes get it to turn on the first time (without going...
I'm having the same issue now. Did you ever figure out what was wrong with your unit? Was it a bad lamp? Mine is only 9 months old, low hours, but perhaps a bad one? Can't understand why it would light sometimes but not others.
Jul 01, 2009 | Mitsubishi HC5000 LCD Projector
Sim card, turning self off
the mainboard either needs to be flash or take the phone and have the board replaced.
Dec 11, 2008 | Motorola Mobility RAZR V3
Buttons not working
you need to have the phone flash and service take the phone to a mobile service center and have them do it there for you.
Sep 04, 2007 | Motorola Mobility RAZR V3
Flashes orange 2 times every 5 seconds
There is a 20 pin cable that goes from the main board to the light engine that can cause this issue. The other possibility is the door switch or the cable that leads to it has failed. If none of those correct it then the light engine itself is the problem. Hopefully one of the earlier mentioned items is the issue as the light engine is costly. The part number for the cable is LSJA0467 and is available here http://www.partstore.com/PartNumberSearchResults.aspx?PartNumber=LSJA0467
Mar 26, 2007 | Panasonic PT-43LC14 Television
Canon PowerShot A530 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
