Question about Canon PowerShot A530 Digital Camera
My flash won't work!!!
Sometimes when I try to take a picture with the flash, all I hear is a clicking noise. The orange light on the front shines for a moment, and then back off. But NO picture! IT takes pictures without flash, but not with! Can anyone suggest a problem or a resolution? If it's an internal problem, I may as well buy a new camera!
  • Canon Master
  • 4,738 Answers
Check to make sure your camera's not on the A530 recall advisory list. Maybe the flash capacitor isn't getting enough power due to the shorting described in the advisory?:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on Dec 28, 2007
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
No picture or sound
Check the power supply circuit for dry electrolythic capacitors (assuming that occasionaly it works)
Best of luck
Jun 25, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Flashing orange arrow . cant get anything to print
Try taking out the print cartridges and then putting them back in and make sure they are really well inserted when you replace them. Then slam the lid down to really make sure its shut and it should resolve the problem.
Apr 02, 2009 | HP DeskJet 5150 InkJet Printer
Samsung HDTV stopped turning on and made a click sound
if it just clicks and thats it, yeah power supply. see if the fans run and it does the boot up sequence. let it try to come up again and again. it will spit out an error code. If all three LEDs on the front panel flash, it is on the engine side. Try to power up without the lamp and hold down the lamp door switch. You can see if the colorwheel is spinning or not through where the lamp shines.. you can also hear it .. its the high pitched squeel noise you hear whir up. If the colorwheel spins, then the ballast should strike up the lamp. If you hear a 1 second buzz sound, that is usually a bad lamp. The spark gap on the ballast fires if it cannot fire the lamp.. you might be able to see it glow. The lamp can be bad but not necessarily blown. If it looks good, try tightening the connections inside the assembly, the two wires (be careful fragile, glass, mercury, etc.)
Nov 23, 2008 | Samsung HLN5065W 50" Rear Projection...
Fujitsu-Siemens P15 TFT power/picture problem.
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Aug 11, 2008 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Flashing Standby/Stero light and No picture.
How good is your picture when it did come ? Is it as good as it once was ? Or is it alittle washed out. If it is washed out the picture tube is weak . Sometimes turning up the screen control alittle would solve problem but if you turn it up too much you would have faint white line running diagonally. Now if you think the picture was good before you this problem video circuit would be your suspect . Jungle IC or something in the RGB circuits . Good luck
Feb 27, 2008 | Sony KV-35V35 TV
Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot A530 Digital Camera Logo
152 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
