Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
RCA P52921 Color/Alignment Grid
By Nooch01 on Sep 28, 2007
Hey guys,
I have an RCA P52921 that I've had for about 6 years now. It runs great. I had it serviced many moons ago, and the tech pressed a bunch of codes on my remote to bring out a graph paper like grid on the screen. He was basically fine tuning the jets, and said it should be done every time you move. Well, I've moved, and was looking to see if anyone knew the remote code to access this area. It is definitely not the red/blue/green convergence that you see under the screen menu, as that only provides one set of crosshairs. What the tech did turned the entire screen into a grid.
Any suggestions are appreciated.
Comments:
Oct 01, 2007
- thanks Techman. Any thoughts on where I might be obtain a service manual? I'd be interested in reading it.
thanks
Same Problem
Apr 26, 2009
-   my rca tv show reb blue and green when the picture shows
it also makes the picture show blured
-   Guest
Mar 10, 2008
-   I have an RCA P52921 that I've had for about 8 years now. It runs great. I had it serviced many moons ago, and the tech pressed a bunch of codes on my remote to bring out a graph paper like grid on the screen. He was basically fine tuning the jets, and said it should be done every time you move. Well, I've moved, and was looking to see if anyone knew the remote code to access this area. It is definitely not the red/blue/green convergence that you see under the screen menu, as that only provides one set of crosshairs. What the tech did turned the entire screen into a grid.-   james420
Mar 09, 2008
-   help me-   Guest
Solution #1
posted on Sep 29, 2007
Somewhat Helpful)
techman
Rank: Guru
Rating: 86%, 7670 votes
What your looking for is called the service menu. This is not an adjustment you should attempt unless you first read the service manual as the wrong button pressed while in this menu will cause permanent damage and an expensive repair. My best suggestion is for you to call in an authorized RCA repair person to do this for you, or purchase a service manual before you attempt this alignment procedure. Good Luck
Was this helpful?
Yes
No
Solution #2
posted on Mar 16, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a 40'' RCA colortrak2000 projection screen tv... and it has a line at the bottom of the screen when it is turned on. What can i do to fix this problem?
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS... (More)
Answer
Need code # for tivo control of polaroid TLA-04011C tv
Answer
Samsung HLR5667W...a loud hum and burning smell when tv is on sounds like from the fan. It happens... (More)
Answer
The picture is dark, there seems to be alot red in it, and its tightly out of foucs
Describe your Projection Televisions problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
