Question about SanDisk Sansa c200 MP3 Player
My sansa mp3 player 1 gb
I tried to add a couple of songs onto my player and i thought everything was okay bc it said "it is now safe to disconnect player" and so i did but it has been saying that it is "Reading" for a while. i dont know what to do
    Problem Solver:
  • 19 Answers
Try to plug it back in, and if it works, open windows media player and click the arrow below sync and try to format it.
Posted on Jan 24, 2008
SOURCE:
Sansa Clip 2gb only plays parts of songs
The songs you have loaded have a restrictive license on them that only allows full playback on a computer, not on an mp3 player. If you only download songs in mp3 format, you will never have this problem.
Jan 01, 2009 | SanDisk Sansa Clip MP3 Player
My songs wont add onto my sandisk sansa mp3 player
What format are the songs you're not able to hear? It's possible that the songs are not in a format the Sansa can play.
Also, you can navigate your Sansa like a removable drive. Try going to "My Computer" and looking to see what's actually on the drive.
Nov 27, 2008 | SanDisk Sansa e250 MP3 Player
Wont put songs on
I would wait for the writing message to go away before disconnecting the player - this is the standard message it will give you when you are transferring songs to the player. If it still says writing after 5 minutes (this is assuming you are not trying to load more than 20 songs at once), then you might have a real problem.
Make sure the files you are trying to load do not have DRM encryption on them, and also make sure they are in mp3 or wma format.
If you have Windows Media Player 11:
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 16, 2008 | SanDisk Sansa E280 MP3 Player
Why wont my Sansa get songs???
You may have to install Musicmatch and add songs through the portable device menu. It worked for me. Good luck.
Oct 28, 2007 | SanDisk Sansa m230 MP3 Player
Deleteing songs
You can delete them thru My Computer. Double click on the Sansa (m200), inside you will see a Music Folder. Inside is your individual tracks, separated by album names. You can add or delete all music from here. Best of Luck.
Oct 09, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Sansa e200 wont load music
Check if the player is in Autodetect/MTP then try retransferring the songs on the player. And before unplugging the player from the computer check if the files are transferred to the player click on the sansa e200 player on the left window to check if it had really transfferred the songs to the player. If it still wont work, try trasnferring songs using windows media player.
Jul 21, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Jun 30, 2007 | SanDisk Sansa e260 MP3 Player
Computer won't recognize my mp3 player
you could try to reboot/restart the mp3. you are going to have to erase everything and start new, you may have gotten a bug when you were downloading.
Jun 25, 2007 | SanDisk Sansa e260 MP3 Player
Frozen on Refresh Database
Take out the four screws on the back and pop out the battery then put it back on. Make sure you synced the songs properly. Add to the problem how you added your songs and I might be able to help.
Good Luck
Feb 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
