Miele 1203 washer failed during a cycle and buzzer on no fault lights
During cycle buzzer came on and no fault lights but pump running. had repair guy in and he played with sump switch and then machine worked for 2 weeks ok. Now failed again same way when poered on the buzzer is on and pump runs and no other indiactor on but power. press the buzzer button and buzzer off but pump keeps running no other indcators. I have checked sump switch and it is working normally float not stuck and switch measures ok but still fails. I suspect open wire or something else on panel wrong.
  • paulio Oct 02, 2007
    Checked inlet filters on both end of supply hoses and the are clean free of debris. unpluged sump switch and powered on and now get inlet and drain lights on with the buzzer I guess thats ok to show that maybe sump switch is open. have service guy comming back with float and sump switch.
  • paulio Oct 13, 2007
    Wiring ok and there is no rotary switch
  • 790 Answers
Check all the wirings connectuions! and maybe you have dirty rottary switch! you can clean the switch!
Posted on Oct 10, 2007
Washer is not spinning the clothes
What is the make and model? It is most likely a balance switch or lid switch fault causing the issue.
Jun 16, 2016 | Miele Novotronic W1918A Front Load Washer
Start button light flashing will not start
Hi dear.
You need to contact Miele to assist your machine repair. Description as blow. Thanks.
Start LED flashes rapidly
The drain pump (M8) is activated, level-controlled, for up to 1 h.The buzzer sounds intermittently for 2 min irrespective of its setting.Digital display: - - -
Cause
Technical fault.
Feb 01, 2016 | Miele Washing Machines
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
Error code 26
You have a clog some where
F26
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Front Load Washer Repair Not Draining or Spinning How to Unclog the Drain...
May 31, 2012 | Maytag Washing Machines
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Feb 15, 2011 | Miele W 4800 Front Load Washer
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Miele w1203 fault
use the small orange tab to tighten down on the light just inside on the top of the door. i had the same symptoms and it fixed them right away.
Oct 03, 2007 | Washing Machines
Washing Machines Logo
309 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
