Question about Panasonic PT-47WX49 47" Rear Projection Television
Red Covergence - No Remote
Was given the TV, without remote. I have a convergence or IC issue as many others on this board are describing (red is off kliter, causing doubling of image where red is present etc). Would like to try to adjust convergence before taking in for repair, can this be done without the remote? If not any good sources for a remote quickly?
I believe you can hit the menu button located on the front of the tv, scroll to the screen option, then always choose green convergence first, then the others. To make it easy on yourself, you could always purchase an inexpensive universal remote, or even better, an RCA remote.
Posted on Sep 28, 2007
SOURCE:
Panasonic pt 53wx53g
No--you will NOT get anywhere this way. You need a remote.
Apr 01, 2014 | Televison & Video
Can a hitachi convergence be fixed without a remote? seems like red is adjustable, but cannot access the blue line with our universal remote
Ur universal remote was able to move - + from the convergence grid wright,it is a good remote.The tv convergence board is dead.The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts must be replaced on the tv convergence board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 19, 2010 | Hitachi 43FDX01B TV
Hi, My Samsung tv had the bad coloring issues described of as convergence/IC issues. Now it just has a red slanted line going across the top of the tv. In the self focus menu I get an error that says...
You can just replace the convergence board which for your model is part # BP95-00415C They are under $100 dollars and are just a plug in board. You should be able to purchase from
www.partstore.com
Aug 28, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
I have a Samsung HCM4715W and it will not turn on. The remote turns on the tv but ther is no picture or sound. There is a red light on the front that flashes. I counted the flashes and it's 22211.
Go to Encompass Parts Distrubtion for List of Parts and Prices to your TV type in Model number.
You need to replace either the convergence board or Both ICs on convergence board they are big black ICs STK392-020s Mats has them 1-800-628-1118
Covergence board# AA95-02002A
Mar 22, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Mitsubishi 55411 projection tv has red band across bottom
go into the customer menu and select convergence with the original remote; if either the red or blue will not move in some direction, you have a bad convergence IC(the WS-55411 uses two STK-392-110 CONVERGENCE IC chips)
Aug 12, 2009 | Televison & Video
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Colors Misalinged
You have what is known as covergence problems. Ok to begin with. 1 Go into customer menus goto SETUP do you have the "CONVERGENCE" option. If you do not the the likelyhood is you have the fl231 fuse problem and if you can solder and get it i recomend it a simple repair. ok if you have that option then try going in and autoconvergening if that didnt work try manual the red and blue convergence. if in the manual red and blue the crosshair didnt move then you probably have convergence power board problem if only one moved or just move a up and down or left of right then it might be a amp board issue. the other problems it could need a simple factory alignment.
Aug 26, 2008 | RCA HD56W66 56" HDTV
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
