Question about RCA F27669 TV
HIGH PITCHED FROM TELEVISION
MY TELEVISION IS OFF AND WILL NOT TURN ON----YET I STILL HAVE THIS HIGH PITCHED NOISE COMING FROM MY TELEVISION. OF COURSE IT IS PLUGGED IN AND DOES GO WAWY WHEN UNPLUGGED.
  • IshaBug Jan 26, 2008
    I have the same problem. Did you find an answer?
  • Anonymous Jan 29, 2008
    will not come on,at all
More info needed but either your psu needs new caps or you have an overload on a section of the psu.
Posted on Sep 28, 2007
SOURCE:
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Sound Issue
This might be of the core vibration of the backlight inverter transformers.
Dec 09, 2012 | Televison & Video
High Pitched Noise Coming from Sony STR-DH510 LCD Screen - how to fix?
Hello
The problem is with its backlight inverter board. there are some step-up transformeres [small ones] fitted on board. If any one's core bacome loose this fault will occur. Just open the TV and listen to which one makes hi-pitch noise. Replace it, if you can buy it from the electronic market at your town. In most cases, the inverter board needs replacement.
This board can locate on the right or left side of the panel, fitted vertically.
http://www.dataentryjobs.us/67948.html
Feb 17, 2012 | Sony Audio Players & Recorders
Screen suddenly turned off, makes an odd high pitched noise when it tries to turn back on. power button flashes orange
Sounds like there is a power problem if the neutral (return) wire on the power supply has become high impedance (or even disconnected) then you will get a high pitched sound coming from the TV PSU also the voltage that is presented will not be 240V which will give you the same problem.
The orange power button means standby if you fix the PSU then the TV might work again but it may have been damaged by the PSU.
Jan 07, 2010 | Panasonic PT-50LCX63 50" Rear Projection...
Noise coming from the speakers
The right speaker is not tighly connected. Check for
loose connection at the terminals, that causes to oscillate (high noise)
Oct 11, 2009 | Audiovox FPE3000 30 in. HD-Ready LCD...
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
Buzzing noise from rear of 26inch sony flat screen
cheak back light settings turn it all way up if down to low it will buzz in video options
Oct 15, 2008 | Sony KDL-26U2000 26 in. LCD Television
RCA F27669 TV Logo
43 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
