Question about RCA RTD170 System
RTD170 Aux Surround
Recently i obtained a RCA RTD170 Home entertainment system without a remote, ive looked all over and cannot find how to switch the AUX1 or AUX2 into surround, is there any Menu/Button Combo i will be able to press to get this to work, thank you
The manual for a rca rtd170 shows how to hook up the audio on the system for a sat. dish,but not for the video, how do u hook up the sat. reciver to the rca tv and rtd170 system?
Posted on Jun 23, 2008
SOURCE:
HOW DO i CONNECT MY RCA RTD325W SURROUND STYSTEM THROUGH MY COMCAST BOX AND MY TV
Video out on rtd325 to Video in on TV, set tV to correct input source, not red/white cables to Audio or AUX INPUT on the rtd325 and run those to Audio out on the comcast box, set rtd325 to AUX fcuntion when watching comcast
Oct 29, 2013 | RCA Dvd Home Theater System Rtd325w Remote...
How too hook surround system to regular tv. Example : a football game. Thanks
Well, since the "regularTV" has no make or model number I will have to guess what outputs it has to suit your surround sound system which also has no make or model number! Using outputs that show left and right speaker channels wire each to the left and right speaker channels of the surround sound amplifier. How many, I don't know!
Jan 23, 2013 | Audio Players & Recorders
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
How to set up to my tv
Ok...sorry it took me so long to get back to you...Check the back of you tv and look for RCA jacks for audio and video out...There should be a yellow one for video..a white one for audio left(L) and a red one for audio righ(R)...you may not need the yellow one...now look for any inputs on the rear panel of the surround sound system...They can be marked (AUX)...they will work..once all of these are located...you will need an RCA patch cable long enough to reach from the tv to the surround sound receiver...once done...turn on the tv and the surround sound.With the remote from the surround sound remote...switch between the input sources..maybe (AUX) until you hear your tv sound come through...then you adjust the sound as needed...Assuming the DVD is built in to the surround sound system...your DVD sound will come back when you play DVD's...All connections and cables are color coded so you should have no problem connecting everything....Good luck....let me know how it goes,,,,I hope this was helpful....PEACE.....
Jan 05, 2012 | Audio Players & Recorders
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Mar 14, 2011 | Panasonic SC-HT75 System
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Rca rtd170 "player is locked"
no thanks to the solutions listed-i have figured it out! you use the remote that it came with and press and hold the stop button on the remote and the dvd player at the same time and it will open....waalaa.....i'm a friggin' magician man...hahahahhahahaa
Oct 12, 2007 | RCA RTD170 System
RTD170 Speaker Problems
Have to change the set up in the menu section and make absolutely sure it is on surround dolby and not stereo. Check manual for set up.
Jan 01, 2007 | RCA RTD170 System
RCA RTD170 System Logo
176 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
