If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET: - Power the scanner OFF - Power the scanner back ON - Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner - Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Power the scanner OFF - Power the scanner back ON - Press 0 then 1 while "Welcome to Dual Trunking" is displayed. - "Initializing Please Wait" will appear for about 2 seconds.
DO
NOT power the scanner OFF until the INITIALIZE process is complete
(M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure
will reset the scanner to original factory settings and erase all data
that you have programmed.
You didn't mention your location or the type(s) of digital system signals you lost, but if you've been listening to an EDACS system it's possible that the manager has switched on the PROVOICE security option. That would prevent your scanners from recognizing the effected users and would also account for both scanners being effected. If your area is using EDACS I suggest that you visit www.RadioReference.com to check on system particulars.
The PRO-95 is also known for losing its logic and requiring a RESET or INITIALIZE, although it would odd for two units to go squirrelly at the same time.
If all else fails, you can RESET or INITIALIZE the scanners to bring them back to normal operation.
DO
If all else fails, and it sounds like it has, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
- Power the scanner OFF - Power the scanner back ON - Press 0 after the scanner completes its boot routine - Press 1 after the menu appears - Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
DO
DO
DO
Radio Shack calls it "Initializing," but to totally reset the scanner to factory settings,
1. Turn off the scanner, then turn it on again. “Multi-system Trunking Scanner” appears. 2. While “Multi-system Trunking Scanner” appears, press 0. 3. Press 1. 4. Press ENT. “Initializing please stand by” appears for about 5 seconds. When the initialization is complete, M000 appears on the second line of the display. “Bank 0 Ch 00” appears. Note: Do not turn off the scanner until the initialization is complete.
Need the manual for your scanner? You can download/print it here:
If all else fails you can RESET or INITIALIZE the scanner to bring it back to normal operation.
DO
