FixYa.com
Tags:
Brother ML-300 Typewriter
Not typing the correct letters (by 3 users)
posted by garrison on Sep 28, 2007
For example when I type randall it prints %3$<388
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 29, 2008
I TYPE HOUSE AND PRINTS BWO:
Comment by Guest, posted on May 02, 2008
I have followed all instructions as printed in the manual and suggestions submitted through this website and the typewriter still does NOT print the correct letters. Have there been any recent solutions found to this problem?
Thanks Pam
Best Solution
posted on Sep 28, 2007
Thanks for Trying (70)
ElecEngTech
Rank:Master Master
Rating: 90%, 50 votes
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes
position. According to Brother, if this is not done the typewriter will print incorrect characters.
Try these steps:
1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove
the Daisy Wheel by pulling it up and out.
2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey
Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel.
3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward.
4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as
is printed on the Daisy Wheel.
5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter
mechanism and align (or time, in technical terms) the carriage mechanism.
Check if the typewriter prints correctly now. If still incorrect, perform these additional steps.
6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the
I=Standard position. The other positions are: II=International and III=Symbol.
7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the
switch contacts in case they are dirty and not making good electrical contact.
8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism.
If still incorrect, the only other things I can think of is that:
1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with
two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.)
The B type are incompatible with your machine.
2) the typewriter has failed and needs repair.
Rating Locked! (?) garrison has rated this solution as Thanks for Trying
Can you Help with these Typewriters problems?
Brother Correctronic 360 Word...
I have a Brother 360... Answer This...
Changing ribbon
Hi, I have an ML-300. ... Answer This...
beeping sound when powering...
While attempting to install a... Answer This...
Display Mode doesn't work
I want to set it to... Answer This...
Auto Advance
Is there any way to set the... Answer This...
Repair Service
Find Typewriter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
