Question about Countryman ISOMAX E6i (E6IOW5BC2) Microphone
Won't stay in place
I have an oily complexion and during the services, the mic slips out of place and drops down, I continually keep shifting it back in place. It is frustrating. Any good ideas.
That WON'T work
Posted on Jun 03, 2008
  • 31 Answers
The rubber sleve on these mics are made to be adjustable...and you can shape and form these into the best shape for your ear. try forming it into a shape that is more snug around your ear, maybe put it on and then squeeze it a little tighter. Sometimes the arch in the mic. gets places too low and needs to be formed up a little further.
Hope this at least gives you some things to try.
Posted on Mar 30, 2008
SOURCE:
Mitsubishi Airtrek 2001 steering wheel keeps dropping down we took the surrounding covers off to have a look and see the sliders that the height adjuster sits in had come off so we were able to sit them...
"... won't line up to be screwed" suggests the column has shifted backwards. Try to move it forwards to get the bolts to line up. You may need to pull off some dash covers to see what it out of place.
Dec 09, 2017 | Mitsubishi Cars & Trucks
My rpm rev's past 3 car stalls then shifts...sometimes won't shift
Due for a transaxle rebuild,common on that veh
The fact you continued to drive it when it won't
shift correctly & has been slipping, your done
Aug 30, 2012 | 1998 Plymouth Grand Voyager
Kids can't shift down because its too hard to turn??? help
You might be able to improve the situation a bit by getting a little oil inside the cable housing. Get some WD40 with the little tube on the nozzle. There might be several places where the cable enters a cable housing. There might also be a couple of places where the ***** cable has to slide through a groove, like under the pedals. The trouble is that you have to pull the cable hard enough to move the chain, and overcome the spring that is pulling on the other end of the cable, AND overcome the friction that increases the harder you pull on the cable. A little bit of dirt or corrosion increases that friction A LOT. AND there is one more source of friction you have to overcome - the shift lever itself has a kind of friction clutch built into it to keep the cable from slipping back and shifting to a higher gear by itself. You might be able to loosen that clutch a little, but there are hundreds of varieties. Some shifters have a ratchet built in so the clutch only adds friction in the direction you need it - if you have one these, loosening the clutch won't help.
Jun 08, 2012 | Cycling
I have a 2003 mazda rx8 its a manuel anyway il be driving in 5th gear and il put my foot down and the rev needle will shoot up and then drop back down while my speed
Yes it is the clutch slipping, in high gear the greatest load is put on the clutch so that is when they slip the most.
Mar 16, 2012 | 2004 Mazda RX-8
On ocassion, my 1998 LaSabre (with 91,000 miles) won't back up when I shift into reverse. Transmission need replacing?
you need to have the transmission serviced and checked for broken gears. There is a chance its slipping and not locking into place when you shift because of a broken gear and this could cause more issues if not looked at soon. parts break and get jammed inside causing further damage. Take it to a reputable shop and have it checked soon.
Oct 28, 2011 | 1998 Buick LeSabre
99 gmc sierra tow/hual when driving comes on and goes off by its self when in drive/od and revs engine when it does
Check that the orange wire in the right side of your steering column is not cut or broken. It has 2 conductors in it. When they short together, it will turn the tow/haul function on or off each time. If they don't touch each other, the tow haul function won't activate.
Oct 01, 2011 | 1999 GMC Sierra
Hi, I have a 1999 Mercury Villager with the 3.3 Litre Nissan motor. Just recently my cousin replaced the timing belt, and distributor. When we got the van back it was having transmission problems. When you...
I would start by making sure the Trans Fluid level is correct. If the level is good, it sounds like your internal pressures are leaking down, and that is why it slips out of gear. Which means you have internal trans issue which would require the trans to be most likely removed and repaired.
Thanks Jay!
Jul 09, 2011 | 1999 Nissan Quest
I dropped and it came apart
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Jan 12, 2007 | Motorola Mobility H700 Wireless Headset
Countryman ISOMAX E6i (E6IOW5BC2) Microphone Logo
125 people viewed this question
Top Countryman Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Countryman Audio Player and Recorder Expert? Answer questions, earn points and help others
