Question about Panasonic PV-V4524 VCR
Rewind When rewinding a tape, it never fully finishes, it will leave the first 5 minutes of the beginning of the tape un-rewound. It just jams and gets stuck not like it doesn't have enough power. This happens regardless of the tape I use; new, old, standard 5 hour tape, Memorex, Fuji, etc
    Novelist:
    Champion:
  • 275 Answers
Dear Tim, In all likelihood the belts of your VCR have become old and worn. I suggest you unplug the machine, and open the bottom plate. You will now be able to see the Drive belts. Go to a Spare parts shop and buy a Belts set for your nodel from them, and replace. Also, try changing the REW/FF Idler unit. This should do the trick.
Posted on Oct 01, 2007
    Novelist:
    Champion:
  • 254 Answers
Pravin is right on with the likely problem(s). Belt & rubber drive tire problems were very common especially on older VCRs ('80s early '90s). Late VCRs used fewer belts (often only 1 or 2). Also, the idler should move freely- I've seen a few cases where the grease at the pivot pin had dried or become "gummy."
Posted on Oct 02, 2007
SOURCE:
My Philips model DVD750R/17 shuts off when playing a VCR tape after about 15 minutes. Why?
The most likely cause is a problem with the mechanism that moves the tape(when played a bit more weight is on the takeup reel.
Someone would have to open the unit so they can see the reels moving---watch to see if it begins to hesitate when further into the tape.
A trick that can help to see is put a fully rewound tape in and hit fast forward--let it go all the way to the end and rewind--if unit does not stop after doing that see what happens in play.
A worn drive unit that moves the tape can sometimes get better after run this way.
Dec 06, 2012 | Televison & Video
Can you rewind a sony 8mm tape manually? End of tape messed up and trying to get it rewound enough that it will finish
It's been awhile, but I believe there is a round "switch" on the bottom of the tape that is on the same edge that the tape itself faces. First you depress the "switch", and then you will be able to turn the spools that are inside the tape. If you are facing the edge of the tape case that lets you see the tape itself, you would turn the left handed spool in a clockwise direction to rewind it. Hopefully that will help you.
Jul 07, 2009 | Sony Handycam DCR-TRV130 Digital Camcorder
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
How to erase previous recordings..
Hold in the RECORD button and pull 4-way slider switch all the way down into REWIND position until tape is fully rewound.
Jul 02, 2008 | Philips Pocket Memo 381 Handheld Cassette...
Sony SLV-940HF VCR Problem: clicking noise when tape fully rewinds
It is normal. Sony is trying to get your tapes last longer.
Mar 27, 2008 | Sony SLV-940HF VCR
Canon MV500
Perhaps this will help some. I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation applies to you, try the following, and make sure that in the future you don't fully rewind your tapes! Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, near the top (that is, opposite the side where the tape is exposed), locate the notch between the two spools (the "wheels"). The notch will have a spring-loaded slider inside, which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.) Hope that helps, and good luck. In the future, I'll heed the common advice to use the camcorder playback as little as possible, relying on a tape deck for RW/FFand making sure to transfer material to scratch disks ASAP and then just storing that footage away in a shoebox!!!
Dec 11, 2007 | Canon Optura 20 Mini DV Digital Camcorder
My T1000 will not erase tapes.
Press the erase and rewind button at the same time.
Nov 16, 2007 | Olympus Pearlcorder T1000 Desktop Cassette...
REMOVE THE CASSETTE message
I realized that this problem occurs on my Canon Optura 30 (consumer mini DV) when the tape is fully rewound. Tapes that are not rewound seem to work fine. If this situation appears to apply to you, try the following, and make sure that in the future you don't fully rewind your tapes!
Fast forward your tape in a tape deck or rewinder. It should play in the camcorder now. If you don't have a machine to do it for you, you can manually advance the tape with a pointy object and a pencil (the eraser--or your pinky!). On the back of the tape, locate the notch between the two spools (the "wheels") near the top, that is, opposite the side where the tape is exposed. The notch will have a spring-loaded slider inside which you can hold open to free the spools. Otherwise they are locked in place and you can't turn them. Holding the slider open with your pointy object, insert the eraser in the right-hand spool (i.e., when the exposed tape is pointing down and the "spine" of the tape is pointing up). Turn the spool slowly counterclockwise, making a few complete turns, to gather up a short length of tape, enough so you have a few seconds' worth of timecode. Be careful not to leave any slack. You can turn the other spool a little bit (clockwise) to catch any slack; lift the cover on the exposed tape (by holding back the little release) to make sure it is tight. If you're not sure which spool to turn, it's the one that does *not* have a window on the front side of the tape. (If the tape is fully rewound, the spool in the window should look full.)
Oct 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
Player - rewind malfunction
I have a trv-58 with the same problem. One way is to press play and rewind while in play mode.Getting back to the first of the tape is a chore.
Sep 24, 2007 | Sony Handycam CCD-TR416 Camcorder
Panasonic PV-V4524 VCR Logo
285 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
