Question about Frigidaire FRT17B3A Top Freezer Refrigerator
WATER RUNS ON FLOOR FROM INSIDE OF UNIT
WATER RUNNS ON THE FLOOR. I CHECKED AND THERE IS NO DRAIN HOLE ON THE BOTTOR INSIDE. WHERE IS THE WATER COMMING FROM. I ASSUME FROM THE DEFROST CYCLE. BUT WHY INSIDE
    Problem Solver:
  • 5 Answers
The drain should be behind the fridge. Look below for the outlet into a drain pan. The line could be plugged. Look for a pinch in the line or other obstruction.
Posted on Sep 29, 2007
SOURCE:
Why is water pooling under right crisper?
On defrost refrigerators water is drained down the sides to an outlet on the bottom of the interior of the unit and then to a tray under the unit, close to the floor, where it is heated and evaporates.
If he hole inside is plugged then the water will pool inside.
Take out both crispers and try to find the location where the water will flow out. It may be plugged with gunk The inside bottom of the unit may have indented runs where the water will be directed to the outlet.
Oct 27, 2011 | Samsung RF217ABWP (20 cu ft) Bottom...
Kenmore model#59675932402 Top part of fridge not cold it is running but not cold, and fridge has been leaking also
check for ice buildup in the freezer floor,if so then the drain hole for the defrost pan is plugged up and when it defrosts the water from this leaks down into the refrige,you need to remove rear inner wall panel inside freezer and take a small wire and rat out the drain hole under the evaporator coil that goes to the bottom of the unit
Jul 02, 2011 | Kenmore Refrigerators
Water not draining into bucket and leaking on floor
Unplug the unit and remove the water collection container. Using a flash light, look into the inside of the unit where the collection container was. There should be a plastic or rubber tube or just a hole where the water would drain into the container. Does it appear clogged? If not, carefully use a 12" long Zip Tie that will fit into the hose or the hole and carefully and slowly run the Zip Tie into it as far as you can. While rotating the Tie, pull it back out. If this area was clogged, it should dislodge the clog and the water should start draining as it should.
Hope this helped solve our problem. Please let me know.
Mar 09, 2011 | Comfort-Aire BHD-301 Dehumidifier
The unit is on a hardwood floor and there is water damage to the floor. The unit appears to be dry now. Could it have a leak that can't be seen?
The potential for water leaking to the floor is probably still there. Open the door of the unit, look in the back and you will see a white plate; that is the evaporator. When the unit is running, there is a light frost that forms on the front and back surface of the evaporator; sometimes the frost can get a bit thick because of air laden moisture infiltration or the frequency of door opening. That frost eventually will melt and drain from a drain hole right underneath the evaporator. If that drain hole is plugged up, water will eventually leak out from under the door. Keep that hole clean and patent and also check the state of the water collecting pan underneath the the unit. That might solve your water problem.
Jan 21, 2011 | VinoTemp VT-TC32G
Freezer on bottom , pools water freezes eventually spills on to Kitch floor must hammer out froozen ice on freezer floor and remove whats the problem not paying buy cc I read your terms of use and as i...
you have a clogged defrost drain
get out all the ice
take off the back panal
and clear the drain pull the unit out and take off the machine compt panal
look under you will see the defrost tube drain
make sure this is draining properly
once you do that take a flat head screwdriver in make the whole in the tin heat reflector more round
what happens is a thin sheet of water covers that hole and eventualuy builds up...
go back to the back, and ensure the drain is clear i usually take it off and runn water through it
some times ive found a small screw in it from assembly
barring all that
make sure the fill tube from the ice machine is properly installed
but i would tend to think its more of a drain situation
Oct 08, 2009 | Refrigerators
Unit runs but water collects on the floor
The drain hole within the unit is most likely plugged up with an accumulation of crud. (Common problem). Depending on the make/model, you may be able to access that drain hole by simply removing the collection bucket. If not, then unplug the unit and remove the housing to gain access to the internal drain.
Jun 19, 2009 | Goldstar DH304 Dehumidifier
Floors in passenger and drivers front are wet 2004 cayenne
Your air conditioner water drain holes are blocked. Check the exit holes for water from the evaporator unit under the foot wells or dash unit. Through these holesor unblock these and the water will flow through to the outside
Mar 23, 2009 | 2004 Porsche Cayenne
Miele dishwasher g843 scvi water backed up on bottom of unit
When you drain the sink the water will go to the path of least resistance. Disconnect the dishwasher, cap the hole and see if water drains. If not then you have a plumbing issue.
Inside the dishwasher there is also a non return valve located in the sump. This should prevent water from entering the unit. Make sure it is in correctly.
Sgt 48
Jun 01, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Frigidaire FRT17B3A Top Freezer Refrigerator Logo
80 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
