Dryers
Problem for Dryers
Generic problem for all Dryers
Heat element(spring) does not stay on lon...
By jwalia on Sep 28, 2007
Heavy clothes like jeans, towels etc takes longer to dry. spring on back turn red give heat, does not stay long enough. I took thermostat switch out and then spring stays red all the time. Do you think it is the thermostat problem or some thing else?
Model: Eaton Viking 5,model# ED307FW429,
S/N- EC568287
Comments:
Sep 28, 2007
- Thanks for your help.
Best Solution
posted on Sep 28, 2007
Helpful)
barnsleymick
Rank: Guru
Rating: 86%, 378 votes
you found the problem yourself, yes its a thermostat, replace this, however the heat should stop on longer than it does,
but please note this is a part that should cut out & reset itself, if needed to prevent fire or overheating, this part has gone what we call tired,
do not bypass anything on the appliance and use it, this can be dangerous and is against health and safety law etc
before continuing to use the dryer check all pipes for blockages as restriction of air flow causes the problem you have, so to prevent another faulty thermostat clean out properly.....
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dryers
Questions and Unsolved Problems for Dryers
Answer
dryer will not heat and heating element is good.
Answer
how about a 100% dryer and tell me about the advs and disadvs
Answer
Takes forever to dry clothes on a frigidaire modle# fde436res1. The exhaust seems tobe hot and... (More)
Answer
Drum wont turn, belt is intact, where is motor?
Answer
On my whirlpool dryer their is no heat. The only way to see the ignitor is through an inch wide hole... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dryers:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
