JVC TV picture problem
Hello, my TV is having issues with its picture. Initially is was just when it was warming up but now its permanent. Basically the picture is stable - no rolling, but there are horizontal lines across the screen flickering, the lines are about 3 to 4 inches apart and about half an inch wide. This is coupled with a whistling noise, although the sound can still be heard over it. Its a JVC tv, AV32T5EKS. Does anyone have any idea what it might be and how to fix it? Thanks Alex
SOURCE:
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 298 Answers
SOURCE: JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Posted on Apr 01, 2009
SOURCE: Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Posted on Dec 15, 2009
SOURCE: The TV has horizontal lines across about 5 inches
Horizontal lines are relatively rare problem in LCD TVs.
The likely problematic areas are:
1) The LCD itself (the micro ICs embedded into the LCD panel structure); that doesn't sound likely based on what you say, but it's not completely impossible. The bad news is it's mostly uncurable.
2) The power board A-1511-322-D G5
Power boards may sometimes cause problems with display, although rarely causing horizontal lines.
I wouldn't start looking here either, but it is certainly a problem to consider.
3) Main board 1-876-561-13 R1506072C
Slightly more possible and yet not quite likely. A high operating temperature and bad SMD soldering process may cause some soldering contacts on the main board to behave differently when the board is cold versus when it heats up. It is very common and may have all kinds of different effects on the TV and the screen.
One way to check for that is with a regular dryer..the process is explained in many other solutions at fixya and around the net, so I wouldn't repeat it here...but it takes time and patience.
4) The most likely place to start with is the T-Con / LCD controller
404652ASNC6LV4.1 M139.
I'd first replace that and see if the problem goes away.
5) There's a very minor chance that the LVDS cable that connects the main board with the T-Con does not make good contact initially and changes that as a result of getting hot. It's easy to just touch and move it lightly when the TV is still cold to see if it has an effect on the picture.
Sorry I couldn't just nail it for you, but that's the nature of the repair businss :-)
Bobby, www.coppelltvrepair.com
Posted on Mar 15, 2010
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
I had one vertical line it cam and went for awhile then stayed permanently and I took it in for repair only to be told they couldn't fix it now they are trying to give me a used tv (warranty don't want to pay) but I refuse I purchased it new and I told them I want a new one. I had that tv less than 2 years. So if you have a warranty and lines get it in fast.
Posted on Mar 26, 2010
Why does my Samsung LED TV now have a permanent blue hue to its picture?
The t con board digitizes your picture and is responsible for anything you see on the screen including any and all anomalies. I would go that route TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Samsung Televison & Video
Jvc tv
picture tube may be busted...check it it might need replacement
Aug 13, 2008 | JVC AV-36260 TV
JVC AV-48WP30 problem starting up
The old video card has seen better days, methinks. All those symptoms lead one to conclude it needs a 'substitute' to enter the field, or call a long TV time out(too much pro and super bowl isms, eh?)..
Are you planning on doing this yourself?
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
I have just purchased a used JVC D series tv and the screen rolls until tv warms up what can i do to troubleshoot this issue myself?
got a jvc d series floor model projection tv, it turns on but it rolls till it warms up what is the problem...
Oct 01, 2010 | JVC Televison & Video
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
My Mits 62"initially has no picture and loud noise until warms up
all of these tvs had bad caps.. that is probably your issue, as they can cause lots of symptoms.
here is my tutorial on this
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Jun 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
TV has dim picture
Hi and welcome to FixYa,
Initially, it would seem to be heat related and/or a cold solder issue. I doubt very much if any major component is defective, at most probably would be a capacitor in the main B+ line leading to the HOT (horizontal out). But that has to be confirmed visually and/or a voltage check on initial power up. best approach would be to open the rear, do some voltage measurements before warm up and after warmed up. Compare these readings and reference the Service Manual. Of course special care and attention since you would be working on a live set.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Jvc av27d201 tv screen problem
You need to have the vertical output IC pins resoldered
Jul 16, 2008 | JVC AV-27D201 27" TV
Screen stretched on JVC AV-28WT5EKS TV
There are some parts that have failed in the horizontal scan amplifier. You will have to have the set serviced by a TV service tech to determine the exact failed parts and have them replaced.
Jerry G.
Jun 27, 2008 | Televison & Video
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Ekse
