Question about Mitsubishi PK18FK/FL Air Conditioner
Mitsubishi air conditiner
I have a conditioner model MUH18RV It's scince 7 years ' a week ago the ac power turn down when the compressor turn on . The power turn off in the cold and heat modes and not at the fan mode . My dealer told me that i have to replace a new compressor. So i have to check my dealer anamnese . Htank a lot Omarih
  • vijayhai Jun 14, 2008
    My remote not functioning.
    Problem Solver:
  • 5 Answers
What?
Posted on Sep 29, 2007
Mitsubishi ac keeps on turning itself off
If the compressor overheats, the clixon circuit will shut off the power to the motor to prevent damage. Then when it cools it will close the circuit and the compressor will again run to only shut down again.
The suction line going to the compressor should be cold - the cold gas returning to unit cools the hermetically sealed motor. If that line is hot you may be low on refrigerant.
Feb 19, 2014 | Heating & Cooling
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Maytag Heating & Cooling
Ac has freon, but blows hot air when turned on! also, had compressor replaced 2 years ago!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 20, 2011 | Heating & Cooling
Mr. silm 42000 btu air conditioner in door working outdoornot working
mr. slim air conditioner good brand. wall type or casset type (Roof model)?..
1) may be your control processing unit (PCB) damage.
2) Refrigerant gas leaking. low pressure switch off.
3) Compressor not working properly.
4) This is 3 phase model may be Ac power not correct.
my opinion call Service person.
Mar 22, 2011 | Mitsubishi Heating & Cooling
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
Brick Air blowing hot air
if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
Jul 25, 2009 | Heating & Cooling
My compressor will not start.
There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC.
Four button reset -
Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons
(temperature UP and DOWN) and hold.
While holding these buttons down, depress the
MODE button once and release.
Release the two buttons previously held down.
Depress the MODE button once again.
At this time the light should extinguish, and the mode
should register “OFF”. If not, repeat Steps 2 through
6.
Retest system ensuring that all functions are present
and operational.
Hope this helps,
Jeff
Rate me please!!
Jun 28, 2009 | Dometic 57915531 Air Conditioner
A/C compressor fan won't turn on by itself.
there is a problem with your fan i'm sure. change the bossing of your fan it will work good.
May 20, 2009 | LG LB8000ER Air Conditioner
Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Air conditioner blowing hot air
low on freon,compressor not running,if its a heat pump could be reversing valve stuck,maybe heat strips are on
May 17, 2008 | Ruud UAKA030 Air Conditioner
Mitsubishi PK18FK/FL Air Conditioner Logo
183 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
MightyMikeJr
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
