Question about Kenmore Oasis HE 27082 Top Load Washer
F Code Bought a Kenmore Elite Oasis washer Canyon Capacity 1 year ago and now that the warranty has expired I keep getting the F code. I ran the clean cycle and it helped but only for about a week.
  • 3 more comments
  • FDawg Oct 01, 2007
    F is the only thing that shows, no number follows just dashes.
  • nannookie Nov 03, 2008
    I have the same problem. My Kenmore Elite Oasis HE keeps showing the F code. I did not purchase the extended warranty. I really think Sears should give me my money back for as much as I paid for this machine! I can not get this machine to work without giving the "F" code.
  • Fjp5050 Dec 21, 2008
    Kenmore Oasis HE model 110.27082601. Everything stopped in rinse cycle. Now I can turn it on but there is no repsonse to the cycle. The water does not start and the lid is not locking. The machine is no more than 1 1/2 years old. I could hear a little funny noise in the spin cycle last night.
  • travelingjo May 11, 2010
    I got a F68 code.  What should I do next?  Thanks.
  • Anonymous May 11, 2010
    I get a F-32 when I do the press/hold 3x's process, then what?
  • 447 Answers
The display is showing u something else look for the F then another letter or number. F is not a valid code
Posted on Sep 29, 2007
  • joey  shearer
    joey shearer Oct 01, 2007
    well the main board must be faulty because there is no F code in my service manuals
  • joey  shearer
    i just found more info on that code ok i apologize it was in the manual but its very vague on the description it says press pause/cancel once to clear the code and then press start is does not say why it shows this code it also says if code persists call for service so i take it as a main computer failure and that is likely what another service tech will say
    try putting it it diagnostic mode by pressing any button
    on for 3 secs
    off for 3 secs
    on for 3 secs
    off for 3 secs
    on for 3 secs
    the control will then display for 5 sec 88 and all leds on
    if there is any saved codes it will then display f then a number and all the leds will flash
    if there are no codes it will continue to display 88
    Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
F Code - moz-screenshot.jpgDU flashes if the following conditions occur:
  • ➔ Excessive force on door lid is preventing lock bolt from
retracting.
  • ➔ Wash media buildup is preventing lock bolt from retracting.
  • ➔ Machine/motor control cannot determine if door lock is in an
Primary Control Failure
F then 1 flashes when there is a primary control failure. Replace
the machine/motor control assembly.
Keypad/User Interface Failure
F then 2 flashes when in:
  • ➔ Diagnostic Test mode if a stuck key is detected.
  • ➔ Standby mode if there is a user interface mismatch.
ATC Thermistor Open/Short
F then 40 flashes when the ATC Thermistor is detected to be
open or shorted. See TEST #5, page 11.
Motor RPS Thermistor Open/Short
F then 41 flashes when the motor rotor position sensor (RPS)
thermistor is detected to be open or shorted. See TEST #3,
page 9.
NOTE: This error code is only displayed when viewing saved
fault codes. See Diagnostic Test, page 2 for accessing saved
fault codes.
Heater Thermistor Open/Short (Not used)
F then 42 flashes when the heater thermistor is open or
shorted.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS)
senses no rotation.
➔ Does basket turn freely? If not, make sure bottom shipping
pack has been removed. Determine cause of friction.
➔ If basket turns freely, see TEST #3, page 9.
Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor
(RPS) failure. See TEST #3, page 9.
Motor Stop Failure
F then 52 flashes when the motor rotor position sensor (RPS)
senses rotation after stop command. See TEST #3, page 9.
Motor Control Overtemp
F then 53 flashes when the machine/motor control detects high
temperature for the motor module.
➔ Does basket turn freely? If not, determine cause of friction.
Motor Control Overcurrent
F then 54 flashes when the machine/motor control detects high
current for the motor module.
Basket Re-engagement Failure
F then 72 flashes when the basket check routine fails to
determine if the basket is re-engaged after being disengaged.
➔ Is the basket floating? If yes, pump out water. See Long
Drain on page 6.
Posted on Feb 22, 2009
I don't know
Posted on Nov 04, 2008
Just got my washer repaired today......the kenmore repair guy said that any F code is a fatal error to communicate with the computer and machine and the "interface board" has to be changed out $200.00. I know this because I made him so me his code book from kenmore.
Posted on Oct 10, 2007
2 Suggested Answers
SOURCE:
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis squeels when filling with water
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
DU code for kennmore elite washer
I have the same problem. I replaced the lock latch and the code still comes up and note I I'm back to square one. Ugh I wish there was a way to disable the dash and reset it.
Sep 07, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
I have a Kenmore Elite King Size Capacity Washer and it displays an F code. It will not go through a full cycle. What could be the problem? Thanks.
in the back panel you will find a tec sheet with f codes . like f1 f2 f3 f4 f5 and so on but just a F ??? hope this will help mm
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
I have problems with my kenmore elite quiet pak2
hi thanks for the question the dlf code for the duet says drain pump remove bottom panel the pump is on the right but there is a big nut in the front remove the nut use bucket as water will come out and clean filter thanks please accept and a positive feed back is nice thabks the appliance doc
Sep 17, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Cycle stops - F error code
I am having the same problem with the "F" flashing and a beep but no numbers. The manual only says to hit the stop button then the start again. It doesn't give you a problem. It then says if this does not work to call a repair man. Mine is only two years old and we loved. I have never had any problem with it but every review I have read says differently and they seem to happen around the two year mark. It seems they have a malfunction timer that goes off at the two year mark. If you find a solution please post again.
Aug 06, 2008 | Washing Machines
Kenmore Oasis HE 27082 Top Load Washer Logo
1,403 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
