Question about Compaq FP 7317 17" LCD Monitor
Screen Angle My screen seems to be leaning back facing up towards the ceiling more than usual and I can't adjust it to face me , although it does appear to have a thing that looks like you could adjust it but it won't budge and I don't want to force it.
  • Steph Burton
    Steph Burton Sep 28, 2007
    I looked for adjust buttons but don't find any.
    Scholar:
  • 151 Answers
You can change the screen with the help of adjust buttons given on your monitor.
Posted on Sep 28, 2007
In the battery cover latch case of my SS-1000, there is a diagram to instal the two AAA batteries and indicates the correct polarity, the bottom one face + to the left and the upper one toward the opposite...
For SS-1000, the bottom AAA battery should have the + polarity towards the top of the camera and the upper battery with the - polarity towards the top. If your camera doesn't turn on, then it may be defective. Please contact Intova directly by email: fatema@intova.net or call us directly at 808-837-0074 for customer service/warranty coverage. Thanks.
Sep 23, 2013 | Intova SP1 Sport Pro 12.0 Megapixel,140...
Wuich way should the teeth be facing on radial arm saw with or against rotation?
As you face the saw, the edge of the blade closest to you is going down. The teeth should be pointing down also. On any circular saw (table saw, miter saw, etc.) the teeth of the saw should point in the direction of rotation. It might seem odd because as you draw the radial arm saw toward you, the saw wants to "climb" and pull itself along through the material. Some saws are equipped with a damping device to prevent the saw from lurching forward, most are not. You need to pull the saw toward yourself slowly and steadily to keep it from climbing. good luck
Dec 28, 2010 | Dewalt Saws
I have a hp webcam 101, i can only do video chats, i want to be able to send webcam to many users, any help?
Well it sounds like your webcam is working, join a group like Earthcam to broadcast to many people
Jul 29, 2010 | HP Webcam
I need the location of the thermistor on an LG WM2496HWM
spin the unit around so the back is facing you. tip it forward so the front of the unit faces the ground. i just lean it on the wall at a angle where it stays put. lay on the ground under the unit and look towards the front of unit right there on the bottom of the drum you will see the heater and thermistor. the heater has 2 hot wires and a ground going to it. the thermistor has a plastic locking plug with a blue and white wire. it just slides in and out of a rubber grommet. good luck
Feb 20, 2010 | LG Washing Machines
Not seeing anything through the viewfinder when switched on
Most cameras and video recorders now display picture either through the viewfinder or the LCD screen.
Your camera model allows the same. Although if you turn the lcd screen towards the subject (screen faces the same direction as the lens) then the viewfinder switches on.
Sep 26, 2009 | Canon ZR200 Mini DV Digital Camcorder
Confused....
What???
The lens is considered 'facing' towards the source of the image. The camera body / sensor / film is considered to be 'behind' the lens.
you are facing the lens when the camera and lens is in front of you, regardless of where the camera is aimed.
The lens is facing the ceiling if you point it upward as if to take a picture of the ceiling, regardless of where you are facing.
Jun 23, 2009 | Olympus Stylus 710 Digital Camera
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
INFOCUS Screenplay LCD projector...
Hi there
I take it the Projector is ceiling mounted ?
If this is the case check that it is installed with the lens of the Projector in the facing straight to the middle of the screen or try adjusting the bracket's swivel head to move it a bit - should do the trick !
May 10, 2008 | InFocus ScreenPlay 4805 Multimedia...
Blurr picture and very red faces
Open the front cover of the tv and try to adjust the screen adjustment thruogh the screen variable resistor.
Nov 17, 2007 | Panasonic PT-53TW53 53" Rear Projection...
TFT Screen Loose Connection?
Hello!
These models sometimes have a problem with flickering screens, screens going black, etc. This is caused by the cable running from your LCD lid area to your motherboard.
To gain access to this cable, flip your laptop upside-down, but make sure the back is facing you (vents and such). There are 4 screws along this side, you only need to take out the middle two.
Once that is done, flip your laptop upright again, open the lid and pry up the power bar. The cable you seek is running on the right side, should be wrapped in gray-colored tape.
Adjust this cable so that it cannot move and is not being pinched, and you should be set.
If that didn't work, and since your LCD is no longer lighting up at all, I'm almost leaning towards your problem being your inverter board. Very easy to swap out, and cheap at around $20 at darntoothysam.com.
The LCD inverter board is located at the bottom front part of the LCD lid. Just take off the front frame of your lid by removing the power bar (as instructed above) and then removing the screws under the rubber bumpers on the LCD frame. Then it's just a matter of carefully peeling the glue holding the frame down at the bottom.
Your inverter board is the long green-colored board you should see with the front frame removed. This board will have two connections plugged into it. Quite the easy swap, yes?
Nov 06, 2007 | E-Machines M2350 Notebook
Compaq FP 7317 17" LCD Monitor Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
