Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printin A message'print unable 30'. This occurred after a paper jam. I've removed all the jammed paper and I've cleaned it as well. And still I have the message.
  • 2 more comments
  • Tequila46 Sep 29, 2007
    Thank you so much. You were spot on. Great problem solver Guru!!!!!!!!!
  • janell jackson Dec 07, 2007
    help
  • src123 Apr 06, 2008
    Can you further describe the position of the encoder strip? Is it on the rail toward the front of the printer or the back of the printer? Is it directly attached to the printhead assembly?
  • Anonymous Apr 23, 2008
    paper got jammed, got every piece out don't see no more, clean machine and still have unable to print 30
I don't know exactly what I did but I felt around for the foil and pressed it against the printer head and kept my fingers crossed.  Then the printer went through the cleaning process and, lo and behold, I now have a printed sheet of paper.  Brother's website and owner's manual have NO trouble shooting guide worth using!
Thnaks for the fix!
Posted on Oct 27, 2007
With my printer, model mfc 665cw, it's really hard to access the encoder strip because it's blocked. I managed to find it by gently running my fingers where the paper jam had occurred and I found it. I applied alittle pressure all the way across the strip to move it down in place. The printer went into a cleaning mode and began to work properly again. Thanks (mix-it-up) for the heads up that that was the problem.
Posted on Oct 18, 2007
  • 832 Answers
The CR encoder strip is not in position. Its the encoder strip which gives the printhead the position. It runs upon the printhead (a small foil strip). BTW this happens quite often because the jammed paper lifts the strip out of position. You ve to open the printer and simply put the encoder strip right into its rail between the senor upon the printhead again.
Posted on Sep 28, 2007
  • Mix-it-up
    Mix-it-up Sep 29, 2007
    This is a fix for owners who have this prob.:
    This fix will prevent the encoder strip to lift out of position when a paperjam occures.
    Use a smal plastic strip (0.5 x 1cm) and a tape strip (0.5 x 3cm). Position the plastic in the middle of the tape. Stick the tape onto the printhead where the encoder strip runs. The plastic prevents the encoder strip to stick on it.
I HAVE A PRINTER BROTHER DCP-T700W AND RECEIVING PRINT UNABLE 35 ERROR MESSAGE AFTER REMOVING A PAPER JAM.
great day, unable to print 35 means, paper jam, first open the the scanner cover, and see the strip encoder, ( Transparent color) and clean it with a piece of tissue. thank you
Nov 20, 2017 | Brother Office Equipment & Supplies
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
Unable to print or copy, see troubleshooting 51
The error means you have a paper jam or one of the sensors is incorrectly reading a paper jam. Unplug the unit and check all areas for a jam. Remove the back Jam Clear Cover and check inside there. Remove the Paper Tray and check that area and check if the PE actuator is in place behind the paper tray. Lift the scanner flatbed unit and check inside the print carriage area. Look for scraps of paper at the sides of the platen. These scraps that may be soaked with ink and difficult to see. You may need to move the print head to see both sides.
If the PE actuator is missing, contact Brother for a replacement. Put in the replacement if needed.
Close the scanner unit, replace the clear jam cover (put it on correctly) and replace the paper tray. Plug in and turn on the printer and see if the message clears. If it doesn't clear, access the Ink or Ink Management menu (either directly by a single key or through the menus). Do a test print for Print Quality (Color). If the quality is good, press 1, the up arrow or + key to select Yes. Then press the Stop/Exit button. If the print quality is poor, clean the print head.
If the jam message occurs again, check for more scraps of paper inside the unit as above. Make sure your paper meets the specifications for the printer and isn't getting excessively humid. (Paper will pick up moisture from the atmosphere so keep only the needed amount in open reams or the paper tray.) Fan the paper in the tray and then return it to the paper tray. Make sure the paper is flat in the tray and that the guides are just touching the edge of the paper.
If it still doesn't clear, the unit needs service.
I hope this helps.
Sep 14, 2010 | Brother MFC 240C All-In-One InkJet Printer
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 17, 2009 | Brother MFC-665CW All-In-One InkJet...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
483 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
