Question about Vacuums
Fantom upright vaacum- cyclone XT
Vacuum motor not running. Brush motor OK. How do you get to Vacuum motor? Information needed to disasemble to motor level. Have not gone beyond brush motor checkout. Thanks
  • Animull Oct 18, 2008
    Need Vacuum motor for Cyclone XT.....
    Email me if anyone knows where to get one.
    Thekahboom@yahoo.com
    Thanks !
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
Posted on Dec 06, 2007
Fantom F11063 Cyclone Vaccum
I think the manual can help you in replugging the wires
How did you pull out the wires from circuit board ?
Is it with professional help or through some other means
Sep 18, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Beater brush runs intermittently
try changing the the belt.If it is worn it could cause your problem
Jun 30, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
Remove brush motor
first pry out the lens over the headlights. under the foil are two screws holding the top cover on. just lift carefully and the back of the cover pops off. the motor is easily removed, just one screw holds it in place.
Jun 02, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
Brush wont spin
Sound like it has a bad belt . I would check it and replace if bad .
Feb 22, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Dec 19, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Vacuums Logo
473 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
