Hamilton Beach 40870 Electric Kettle Logo
A
Anonymous Posted on Oct 22, 2013
Lid won't close - Hamilton Beach 40870 Electric Kettle
2helpful
Tiger rice cooker lid doesnt close
I had the same problem. The lid won’t close because it won’t latch. I found that if I tighten the Philips screw that holds the latch, it fixes it.
My smartdrive pride lid came off and I fixed it but now the machine won't work, any suggestions please?
Possible that the lid switch alignment is not proper and so does not activate when the lid is closed. Please reset this lid once again and check the switch continuity with a meter when the lid is shut
Lid won't close
Take the disc out, hold the disc holder down flat, then close the lid. Open up and will work as normal. If this works for you, please visit sun-light. co.uk
Ge washer "lo" light when lid is closed. and won't start after it has run before
"LO" means the washer's lid is not closed
What is the model number?
1helpful
It seems that my 2005 Lexus ES330 trunk light won't turn off. How to check whether the trunk light is off when the trunk lid is close?
Remove the bulb if you think it runs the battery down. the switch is part of the latch assembly of the trunk.
Machine won't turn on Hot Point washer, checked outlet ok
Have you tried to run it for a cycle? What exactly does not come on? Is the lid totally closed?
Why wont my philco washing machine drain or spin
Many washing machines won't spin or drain if the lid isn't closed. It could be that the switch detecting the lid close position isn't working or the tang that presses the switch isn't depressing the switch enough. Check to see if the lid is closing all the way, if so, then locate lid close switch and pressing on the switch with a Q-tip. If other functions stop when the lid is opened and work when the lid is closed then you have another problem. The problem could be in the wash cycle switch, try spin and rinse all the different settings.
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Top Hamilton Beach Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
deton8 von Splosion
ADMIN Eric
ADMIN Eric
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
