Televison & Video Logo
Posted on Apr 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture looks 3-D
The picture on my TV looks like it is in 3-d. Is there a way to fix it? It is an R52WH77 52" HDTV - Widescreen
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Apr 26, 2009
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1723394
Points
23750
Yes its an easy repair if the auto convergence is missing in the on screen menu , you can fix it for about 10.00 at the following link . You would need one of the following 3 items all listed under the RCA parts category.
(1) FL231, (1) DL231 and (1) CP230
They supply instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
1helpful
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
2helpful
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
2helpful
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Hello I am having trouble with my picture on my TV. I can't see the top of people's head. Can you help.
go left and right (arrow buttons) on your tv remote to go from 4:3 format, widescreen, 14:9, etc. If you have non-hdtv (full screen), its best to leave it on cinerama or 4:3/
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
2answers
3 inches missing on both sides
Sounds like it is a widescreen TV stuck in standard view mode. Should have a menu option called widescreen or movie format.
Do you see the whole picture squeezed down or is it actually cutting off the sides of it?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
