Question about HP DeskJet 895cse InkJet Printer
Deskjet 895Cse is "sucking" paper in and stalling
My deskjet developed, in the middle of printing 4 one page documents, a new quirk: It will "suck" the 81/2 X 11 sheet to print it and then stall. This is a new noise -- similar to the one it makes when it is feeding an envelope to print. The noise is coincident with the printer then stalling, all lights coming on and I have to turn off the printer to release the page. When powered up, the printer prints one to two pages of UPC symbols/wingdings, etc... This happens with every software and/or printing from the web. However, printing test pages, or using the "resume" button on the printer to print a test page produces a satisfactory result. As mentioned, I was printing the 4th or 4 one page documents when this began -- the first three printed fine. Help?!
  • 788 Answers
Re: Deskjet 895Cse is "sucking" paper in and stalling
Sounds like the printer is getting a bad command from the driver. Try upgrading your driver. Also it may be a bad document. Copy and Paster your text into a new document to see if it clears the corruption.
Posted on Jan 10, 2008
0 characters
3 Points
When I try to print the orange arrow starts blinking
There are four possible causes for the orange arrow button to blink
1. Out of paper
2. Paper jam
3. Ink cartridge not install correctly or incorrect type
4. Printer stalled
Click on web page
Dec 13, 2010 | HP Deskjet D4260 Printer
Hp deskjet 950c
It is a problem with the mechanic.
Jul 16, 2008 | HP DeskJet 950c InkJet Printer
Although my document is set up for legal size when I print it only prints to the end of the letter size (on the legal size paper).
Try adjusting your paper try or you might just be low on your toner. How long have you had this printer and what kind is it?
Dec 03, 2009 | HP DeskJet 895cse InkJet Printer
How do I cancel a print job?
just turn the printer off...and delete the commands from the error and job have to insist ...and try to open it from control panel or Hp in all programs .if it doesn't work from tray system ...this is the way to annul the commands...if it does not want to ..restart and try it again until it get rid of it ...restarting will make it not see that is used by another device ..
Nov 11, 2009 | HP DeskJet 895cse InkJet Printer
Fixed a paper jam, printer started to print one line
When the printer jamed and you had to pull out the jam, the data being tranfered for that job got out of sequence. On Deskjets when that happens, you need to go to the print spooler and delete the job it is printing or you will have the same problem evertime.
Mar 06, 2009 | HP DeskJet 895cse InkJet Printer
Where is HP DeskJet 895Cse Toolbox.
You have to uninstall the HP drivers and reinstall from the CD
Aug 24, 2008 | HP DeskJet 895cse InkJet Printer
Envelope printing
I don't think there is one. You simply replace your paper with envelopes and configure your software accordingly. They would go in flap up if I'm not mistaken.
Nov 24, 2007 | HP DeskJet 895cse InkJet Printer
HP DeskJet 895cse InkJet Printer Logo
121 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
