Question about Cooktops
Braun K3000: Thermal problem
Hello, I have a problem with the electronic thermal protection that stop the engine in only one minut (and obviously the engine is cold)!!! Any idea??? Many Thanks pivi
0 characters
1 Points
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
Error codes EO 21
Good Morning sisutl, thank you for your question!
Could the error code possibly be E-21? If so, this error is commonly referred to an issue with the oven thermal sensor. Typically, the over thermal sensor is in the open position. A professional would need to verify continuity of sensor harness and connections. Depending on an accurate diagnosis the part may need replacing. I hope this information help to some degree.
Sep 06, 2013 | Electrolux ICON Designer Series E36IC80ISS...
Fridgidare model number mef305pbwf eyes stopped working
Hello James - Thank you for your question! Let's try resetting the range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control), a potential wiring failure or faulty elements. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jul 16, 2013 | Frigidaire Stove / Oven / Range Cooktop...
I have a Whirlpool Accubake self-cleaning oven,model RBD275PD86. My wife ran the self-cleaner, then after a short time, everything went black,as if it burned out the oven. What needs to be replaced to get...
Sep 27, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Cracked glass top stove. is it covered under a waranty? it is maybe 4 years old. brought at sears its a whirlpool stove.
whirlpool offers a five year warranty on glass cooktops for thermal damage only not for customer mishaps so call a certified repair place and they can get you a new cooktop if you tell them that it is thermal cracking
Sep 12, 2009 | Cooktops
Just installed an electric cooktop and the Hot Surface indicator light has been on since installation. How do we fix this?
Sounds like a thermal switch which controls the hot surface light is stuck closed.
If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.
Aug 20, 2009 | Whirlpool Cooktops
Yes you can make adjustments but you need a thermometer to set it accurately, you can buy them at Wal mart for 4 bucks. You will need to see if the thermal bulb is located in the flame, if not you will have to move it when it's cool. Some units have a screw to adjust the temperature some use a sliding tube to adjust the heat you will need to look at the stove to see. If you have the owners manual it will help, sometimes the thermal bulb goes bad and the temp control has to be replaced.
Jun 22, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
Fixing Jenn-Air Custom Control
Sure, I meant to get a copy of the schematic last night so that I could send it to you with the changes. I'll get it tonight and send it to you along with the info I have now. The only thing that will be different is that you won't have independent controls of the dual element burner. For me that was fine cause my wife and I never use just the smaller burner but rather always both. The part #1009577 from repair is an infinite switch which is already being used in the cook top for the largest burner or if not (cause I actually didn't look) for sure it is used in the JEC9536, just the wider model. This part is rated from 8.9 - 11.0 amps or 2,640 watts, when you hook the two burners together I believe it adds up to 3,000 watts so the infinite switch (the biggest I could locate) is slightly under sized. However, I felt most things especially electrical, are over engineered for safety any ways. When you remove the circuit board you will have to drill out the two slots where the two mounting screws will secure the new switch, or you can do what I did and stick a screw driver in the slots and stretch them slightly (very easy to do). You'll need to find two screws that fit the new switch for mounting ( not too long, if your not sure take one off one of the other infinite switches and match it up). I'll have to get back with you on the wiring, it is rather simple though, most of the connections are the same as the other infinite switches. The part number 2FBT6 is just a snap action thermal switch that will replace the thermal sensor that went to the circuit board to light up the hot surface indicator. I tried to use the existing sensor but the hot surface indicator lamp stays lit, so I figured that the sensor was probably a 0-10volt or 4-20mAmp switch that the circuit board monitored and turned on the hot surface indicator accordingly. That is a simple hook up also, however, I have not installed that yet cause I did not find out about the thermal sensor not working for the hot surface indicator until after I put in the infinite switch. Tonight I will install it and let you know what wires go where along with a marked up schematic, maybe even photos if you would like.
Sep 11, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Electronic ignition propane stove not lighting
Look to see if you actualy can see the spark when it clicks, if you do see it, then try to adjust the air mixture....Good luck
Eddie Rentas
Tupper LAke NY
Jul 15, 2008 | Cooktops
Indesit PI 640
i find your problem is short of desame line that why it remained lighting,try to hang the connection to that light,try to find it one by one , the principle of the lighting here is like in the rice cooker when warm the light is yellow when cook it turn to red when you going to see it ,it is one connection only.there is a thermal plate ,when it sense extreme heat it will move that to switch off ,,then when it warm its switch on. maybe there is short to thermal plate or the thermal plate not working even extreme heat it will not shrink...try to find this plate .if my solution help you to understand the problem please rate me FIXYA...
thank you in advance Stevecarr.....
Jun 25, 2008 | Cooktops
Cooktops Logo
67 people viewed this question
Top Cooktops Experts
Barrett Palumbo
Barrett Palumbo
Dan Webster
Dan Webster
Are you a Cooktop Expert? Answer questions, earn points and help others
