Question about EPoX EP-9NPA3 Ultra (EP9NAPA3ULTRA) Motherboard
Boot up problem
I have an Epox 9NPA3 mb. It's a year old. First it was booting up only to bios. Next it was rolling to a safe mode start up screen. I enter in safe mode ( as well as all other options available) the Windows logo flashes and then it reboots all over. It flashes several error codes including 75, 94, 26, and 7F. Bios doesn't find any drives. Tried auto-detect drive. Only finds CD drive, but only temporarily. Next time in bios no drives are found. Any help would be greatly appreciated.
    President:
  • 2,961 Answers
Sounds as if you need to change your cmos battery (Cr2032 on motherboard) first of all as i'ts a very cheap item to replace, then set the bios up again, then try to boot, if still no boot you may need an operating system repair.
Posted on Sep 28, 2007
Main screen with icon comes on then icons go out and a white screen w/currsor and freezes
You should start up your computer from WinPE, a CD residen simplified Windows operating system. It might help you to make some diagnostics. Get it from
http://www.uploadable.ch/file/mKD6atNTMRGF
It's only 121 Mb; burn ISO to CD and boot it . Probably you should change startup sequence on BIOS to boot from CD-ROM
Mar 28, 2015 | Dell Latitude E6400 Laptop
How do i start window 8 in safe mode?
Press Win+R to get the Run dialog. Type "msconfig" and launch the utility. In this window In the Boot tab, check Safe boot, followed by the type of Safe Mode that you want to achieve. Then Apply
OR
When PC Is Not Starting
when start up sequence is going on you need to pass the BIOS splash screen, hold down the Shift key and repeatedly hit the F8 key. Then you will get enter into recovery mode, but it might take a few tries before you achieve that. Then in new com window click the See advanced repair options button. In the next screen, hit the Troubleshoot button. In the troubleshoot menu, click Advanced options, wherein lies Windows Startup Settings. Choose that. The next you will be asked to restart the PC. Then you can see the familiar Advanced Boot Option screen like XP and you can choose Safe Mode there
Aug 30, 2014 | Ahead Software 8 Ultra Windows
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
My laptop screen is blue with horizantal lines. After I installed a graphics card driver everything went fine, but the next day the laptop's display started acting weird. So I turned off the laptop and...
The OS-loading screen is a stong indicator that thee is nothing wrog with your hardware, but it is a driver issue. You need to press F8 as your computer starts up and enter SAFE-MODE.
Windows 7
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
    Figure 11. Windows 7 Advanced Boot Options screen
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
In safe-mode remove & delete the drivers you installed. If you can, revert to your old driver set.
Jan 06, 2011 | Computers & Internet
I have an Acer travelmate290 how do you get it to state in safe mode? I've tried hitting F10 on the bios screen but it will not start in safe mode
hello
whem the laptop is booting just after BIOS screen, hit F8 and you will have boot options. you can choose SAFE MOOD.
Feb 10, 2010 | Acer TravelMate 290 Notebook
Epox EP-9NPAJ
Go into the BIOS setup and select 'Load setup defaults', save and exit.
Sep 19, 2009 | EPoX MB EP-9NPAJ NF4 RET Motherboard
EPoX EP-9NPA7I displays 'F' and '5' post codes
I would start by clearing the CMOS with the reset jumper pin on your mainboard. Then remove all the PCI cards excluding the video card; disconnect the hard drive as well. Boot the computer without the RAM and see if you still get the "F post code." If not download a copy of Ubuntu Linux and burn it to a CD.
Ubuntu 8.10 Live CD
Reinstall the RAM modules and boot to Ubuntu from the CD and run "System Memory Scan" from the Ubuntu Boot Menu. I'm guessing your RAM over-heated and is permantly damaged.
Only the manufacturer knows what the error codes for your board represent; it'd email them from this support link...
EPoX Support Contact
Nov 27, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
Acer quit working
Well, the 1st thing to check is boot into safe mode (F8 at boot) and see if you can get to the desktop.
If you can, run system restore and then see if you can boot to normal mode.
If it shuts down, boot to the system BIOS, and see if the system will continue to run, if it does, then your issue is most likely a operating system problem or a hard drive problem causing an OS problem.
If the system doesn't shut down in BIOS, next is try to boot to a CD. You may have to remove the Hard Drive to exclude it from the issue. If the system boots to a CD and will continue to run, then we are pretty sure the HDD/OS is the issue.
Next would be trying to run diagnostics on the hard drive, if they fail, replace the drive. If they pass, reinstall WIndows.
Jul 11, 2008 | Acer Aspire 5315 Notebook
Installed new graphics card and Windows won't start
If your new video card has a power connector, make sure it is connected to a power plug. If you already did that, it's possible your PC's power supply doesn't have enough power to run all your connected equipment.
To get your old card running, hit F8 repeatedly during boot-up until you get the boot options. Select VGA mode. It should boot up properly then.
Once booted into VGA mode, set your screen resolution to something simple like 1024x768 or 800x600, then reboot.
If that doesn't work, try hitting F5 repeatedly during boot-up to boot into Safe mode. You can then adjust your settings again there.
Apr 06, 2008 | PNY GeForce 7600 GS, (512 MB) AGP Graphic...
EPoX EP-9NPA3 Ultra (EP9NAPA3ULTRA) Motherboard Logo
519 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
