SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
SOURCE: oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
SOURCE: I have a 6 burner
Dear Kathynearing,
Hi. I have experience cooking in a burner like that it keeps on burning coz the ignition coil was press by your switch knob coz the spring was stack up try to release it so that it will not be ignited all the time when your cooking. This should be ignited at once. If it gives light already it should be released. Please reply if you have solved the problem so that I can give you more advices.
SOURCE: Thermador won't start self clean. 48
will it bake and broil ok if so check door lock and switch if ok control no longer available must be sent in to be repaired
