Question about Sony SLV-998HF VHS VCR
VCR stops playing
MY Sony dvd/vcr stops playing and the display goes to stop,if I keep pushing the play button the vcr keeps playing but I can see the display trying to stop,it does the same if I FF or rew,it starts to rew but after 4 seconds stops.Do You know how to reset this unit ather than unplug it from the wall.Thank you
  • omarurr Sep 28, 2007
    CONT.
    I have exchanged the vcr mechanics to a know working unit(same exact) and is ok,the problem is in the electronics but I dont have the service manual.
    Novelist:
    Champion:
  • 254 Answers
A couple of possibilities: the bad electronics unit might have power supply problems, optical sensor problems, or other problems with the electronics. If you have some tech savvy and a voltmeter, you could check the power supply voltages. This circuit is likely in the close vicinity of the fuse. On the output side you should see a +5 volt, +12 to 15 volt, and perhaps a -35 volt (approx). The +5 supplies the logic circuit, +12 the motors. If these voltages are missing, or way out of tolerance, you will have a dead unit. A frequent cause of problems in the supply is bad electrolytic capacitors, especially in the older units (Panasonic manufactured rigs, late '80s/early '90s). Possible values on these capacitors: 2200MFD/10V 1000MFD/16V and several others. Replacements can be supplied by MCM electronics, Mouser electronics. I use the Panansonic FC series from Digi-Key Electronics. Sensor problems: Many VCRs have the sensor opticals mounted on the main circuit board, and locate themselves in particular spots in the mechanical section. One or more sensors detect tape loaded, one each for the supply & takeup spindles. If any of these sensors (especially the supply/takeup sensors) are non-working, the logic circuit will detect an error condition, and shut down the unit or at least put it into a stop mode.
Posted on Oct 02, 2007
SOURCE:
Rca drc8295n reset parental codes I bought this unit at a yard sale for five bucks... It plays cd, vhs tapes, but when I put a dvd in it wont play and I see a pad lock on the little display. I am assuming...
Page 55 of the user manual shows a way you may be able to 'reset' the player back to factory defaults and/or if a parental lock has been set and the password is unknown/forgotten:
* Press the STOP button on the front of the unit while you press the STOP button on the remote control-keep pressing both buttons for approximately 3 seconds (until the 'padlock' icon disappears from the front panel display). Release both buttons (the player should be unlocked). If that doesn't work, try resetting the DVD/VCR (instructions are listed below).
* Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button-wait at least 3 seconds before you release both of the buttons.
You'll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR's menus to the factory default settings and also erases the disc library.
( sourced from: http://www.retrevo.com/support/RCA-DRC8295N-DVD-Players-manual/id/402bh648/t/2/ )
You can always go to the above site and download the free pdf of the owner's manual for this model if necessary (follow the prompts).
Give the suggestions a try before considering downloading the documentation.
Apr 26, 2011 | RCA DRC8295N DVD Recorder/VCR
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Apr 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
My Sony DVD/VCR combo will play cds but not dvds. I took the top of the player off and I can see that the dvd spins but it won't play. It used to play everything very well but just stopped working...
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Thanks.
Nov 15, 2009 | Zenith DVP615 Portable DVD Player
Can't see "Setup" screen, or any other screens on t.v. monitor
There should be a tv vcr button on the remote control. What you done was you accidently shut off the VCR function. If you hit that button again the tv vcr button it will come back on.
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Sony RDR-GX315 DVD 3 problem
sounds like your laser is getting weak. repair is usually not economical. laser is about 90% the cost of the unit. hope this helps if it still plays but not record. keep it as strictly playback unit.
Jun 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Vcr
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP for five seconds to restore the
picture to normal operation.
Aug 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
TURN OFF PROGRESSINE SCAN ON ZENITH XBV443
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 16, 2005 | Zenith XBV443 DVD Player/VCR
Sony SLV-998HF VHS VCR Logo
667 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
