Question about Husqvarna Zero Turn Mower Z5426
Hydrostatic transmission My Husqvarna ztr creeps backwards when in neutral. what could cause this?
5 Suggested Answers
  • 4 Answers
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
Posted on Sep 16, 2009
kevin_getz
  • 1031 Answers
SOURCE: husqvarna riding mower will not go forward or backward just stays in neutral
You either have a linkage problem or an internal problem in the transaxle.
Posted on May 15, 2012
  • 6468 Answers
SOURCE: Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Posted on Jul 31, 2012
  • 6468 Answers
SOURCE: HYDROSTATIC TRANSMISSION NOT WORKING ON NEW MOWER
there is a rod on the rear of the mower that is pulled back and lock into place this is there to push the mower around when not running it just lift the lever up and it should pull in then your ready to go
Posted on Sep 05, 2012
Srx75 jd placed in neutral and can not push forward or backwards
many have a transmission disconnect lever at the rear or the mower .usually they are full hydrostatic transmissions
Oct 11, 2016 | Garden
Husqvarna zero turn mower steering problems how to adjust neutral and balance steering
There is adjustments on both steering arms located under the seat. You can make the adjustments by lifting the unit's wheels off the ground and determine if the are "creeping" when the unit is running. Adjust the linkage until neither wheel creeps. Then the tracking can be adjusted by turning the screws located at the base of the steering levers.
Note, the levers do not return to neutral automatically.
Jun 10, 2016 | Husqvarna Garden
Hydrostatic transmission in YTH2348 is very weak, pulls intermittently then stops. I changed the oil put 50wt in it, still doesn't work.
hydrostatics will not work with gear oil they take transmission fluid . or hydraulic fluid check with a dealer or read you manual
Sep 15, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Sep 02, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Craftsman Hydrostatic Transmission Fluid Change
Jul 28, 2012 | Poulan Garden
Cub cadet model 1250 hydrostatic still moves in neutral
YOU HAVE TO ADJUST THE LINKAGE DOWN AT THE TRANSMISSION
Jul 14, 2012 | Husqvarna Garden
MY TRANSMISSION IS VERY WEAK, MOVER WILL SOMETIMES STOP, WONT MOVE, OTHER TIMES IT WILL CREEP ALONG. ITS ONLY HAS 300 HRS ON IT.
noted for frequent failure of hydrostatic transmissions, just search this site. you have to buy another transmission or lawn mower.
Sep 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower will not move foward or backwards belt ok and turning fan and pully.
then the hydrostatic transmission is shot, look around for a new one or a used one. good luck as a new transmission will cost as much as another mower.
Apr 14, 2011 | Husqvarna Yard Tractor
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Zero Turn Mower Z5426 Logo
56 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
