Question about Samsung N150 Notebook
Samsung n102sp keyboard function key (Fn) need to turn off
5 Suggested Answers
SOURCE: keyboard problems with samsung nc10 netbook
I just had the same problem and found the solution on here. press the fn key and the numlock key which on mine is the F11 button so i assume its the same on yours. hope this helps.
Posted on Feb 10, 2009
AvioriX
  • 689 Answers
SOURCE: blem keyboard
Hi
Its Numeric keyboard function that you can disable by using FN+Num Lock Keys.
Good Luck
Posted on Sep 02, 2008
  • 661 Answers
SOURCE: MY SAMSUNG NETBOOK NP-N130 HAS
Try to re-enable the startup programs. You don't need that program to enable start-up items. However, you will need to do some digging to find out exactly WHAT has been disabled. Otherwise, you have no other choice BUT to do a clean install, or revert to your last backup. Those options are way more trouble than reinstalling software.
Posted on Mar 10, 2011
computerstha
SOURCE: mouse is not working in samsung n102sp i need help
If your touchpad has stopped working it may be because you have deactivated it by pressing a small button near the touchpad. it may also be activated by pressing one of F keys (F5 for instance) in conjunction with the Fn (function) key usually found at the bottom left of the keyboard.The button combination will look like a finger pointing to a square.
Posted on Aug 04, 2013
Samsung n150 keyboard
Press either Ctrl and Fn or Alt and Fn to switch the function keys off.
Jan 24, 2014 | Computers & Internet
Samsung r510 laptop
I guess you mean the keyboard function act as though the fn key is always being pressed? If so this is likely to be a hardware problem. Look at gently prying up the key (most keys are press fit and can be removed, lift it off as level as you can, should be relatively easy but don't force it!) once off try moving the rubber pad below the key with a small blunt instrument, keep testing other keys while doing it to see if the fn effect ever lifts of, may have got wet or something underneath the key.
Nov 28, 2013 | Lenovo Keyboard
Mouse is not working in samsung n102sp i need help to fix
Aug 04, 2013 | Samsung NP-N102SP 25.7 cm 10.1inch LED...
Gateway laptop nv57h94u model Fn key is on all the time for the function keys
clean keyboard, reboot PC, press Fn key one more time, if cant help then replace keyboard
Nov 12, 2012 | Gateway Recertified - NV Series NV57H94U...
My samsung webcam not working
Normally there are 2nd functions on your keyboard. Like my laptop inorder for me to turn on the webcam i need to press Fn + F5. Check the F keys of your laptop and look for a picture of a webcam. Press Fn key and tap the key that corresponds to the webcam.
Jun 07, 2012 | Samsung R540 Laptop
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
How do i change letters to numbers on my laptop keyboard
Look for a key with this symbol [FN], pressing this will turn on the keys with the numbers on it. Press again and should turn the off. The FN key woks all alternate functions of the keyboard.
Jun 23, 2011 | Samsung N120-12GW Netbook
Num lock activated and can't turn it off
One of your Function keys (F11, F12, etc., usually F11) will also have the NumLock function on them. So when you hold Fn and press F11, it will toggle the Number Lock. Try holding Fn and press F11, this should turn it off (and back on should you ever want to use it again). Your keyboard should be labeled with the various functions keys have when Fn is pressed, you may have to look for the one that reads NumLk.
Sep 09, 2009 | Samsung NC10-14GW Notebook
To use my key board with out pushing the fn button
The Fn key is used in conjunction with F3 to F12 function keys to select second function assigned to these function keys.
Why do you want not to use the Fn key on your keyboard?
May 23, 2009 | Samsung NC10-14GW Notebook
Samsung N150 Notebook Logo
587 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
