Promate sp9000 Lost my charger of sp 9000.difficult to find one or have similar.could you advice?
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
Promate ego3 driver for windows 7
Dears, I am having promate ego3 usb modem installed in win 7 with zain kuwait data sim. Internet is connection with win xp if I use the same but not working with win 7. pls. give your directives.
Thx.
Dec 31, 2010 | Computers & Internet
Sir plz hep me nokia 2626 charger not supported any solution
I advice you try use a similar charger to charge your phone, if the problem still persist, i mean if the similar charger did not charge the phone, it means the charging port of your phone is bad and will need to be replace, i advice you replace the charging port of your phone if no charger charges the phone, replacing the charging port will help and get your phone charging.
Take care.
Jul 06, 2010 | Nokia 2626 Mobile Phone
Battery drained for Bold 9000. It just died on me.
Get the battery charge charged and power on your phone back after the battery has been charged.
Use the charger that came with your bold 9000 to charge your phone, if it does not charge it, get a similar charger to charge your phone and power it on after charging, ou phone will continue to serve back as before.
But if the battery is not charging at all, it means the cells of the battery are dried, so you will need to get another battery on your phone.
Take care..
Apr 30, 2010 | RIM BlackBerry Bold 9000 Smartphone
Mt gba sp wont start up i put it on the charger and still nothing
SP's are old dude, it might just be completely fried. Best you could is open it up and make sure nothing's loose in there. It might also be your battery, try replacing it if you think it's lost all of it's efficiency.
Apr 07, 2010 | Nintendo Game Boy Advance SP Console
PROBLEMA IMPORESORA EPSON DFX-9000 ERROR 3
Aprendizaje hablar español
ERROR 3 - Carriage Return Horizontal Position Error
The SP motor brake signal did not switch ON within 3 secs after turning the printer ON.
La señal del freno del motor del SP no encendió en el plazo de 3 secs después de girar la impresora.
Check SP motor connection or call for service.
Compruebe la conexión o la llamada del motor del SP para saber si hay servicio.
Aug 29, 2008 | Epson DFX-9000 Matrix Printer
Dfx9000
The SP motor brake signal did not switch on within 3 seconds after turning the printer on.
1. Check for disconnected SP motor-related connectors (ROM BOARD: CNSPHS, CNSPM)
2. Check the Interlock switch, and if necessary replace the switch assembly
3. Check both the SP motor and driver. (Always check both.) Check fora broken fuse on the SP motor 42 V line.
Replace the motor assembly and/or ROM BOARD as necessary.
Jul 08, 2008 | Epson DFX-9000 Matrix Printer
Epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
