Question about Durabrand DUR7 Portable DVD Player
Can't find a replacement 10.5V DC power cord
My original DC power cord has broken and I've been trying to locate a replacement. All the universal cords go from 9V to 12V. Can I use one of these other volt levels or how can I find a replacement power cord?
    Champion:
  • 303 Answers
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUR7 DUR-7
Posted on May 31, 2009
6ya staff
SOURCE:
No power
Try another outlet, cord/charger, with the EXACT same power specs. Has the cord plug been pulled while pluged in damaging the AC jack? Does the computer boot on battery power?
Feb 20, 2013 | MSI A6200-059US Laptop
Laptop won't charge
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 12, 2013 | Toshiba Satellite Computers & Internet
Adapter from power cord gets power, but is not charging samsung rv511 laptop
Step 1:
b> If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Feb 12, 2013 | Samsung Rv511
I need charger for netset pro44 scanning receiver please
  • Hi, i can help.
  • The original is not really gonna be find-able. But there is a DC/DC and AC/DC power cord that are the replacement for them.
  • For AC/DC you can go anywhere and get a 9VDC - 300 mA AC/DC wall wart with a 1.3 mm / 3.4 mm. plug. Radios Shack have gone to selling universal wall worts and selling the tips for them separate. So if you go to radio shack use tip "H" along with the spec I listed above. They will know which one if you give them that info.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 19, 2011 | Radio Communications
The power cord is basicly broken. I can still charge my laptop but I have to twist the end of the power cord in my computer and hold it so it will charge...
Sounds like you need a power cord - best option is to take the busted cord to The Shack (radio shack) and they have a universal power cord and they will help you match the tip so it fits in the laptop. I've done this for MP3 players and other devices and only costs about 30 bucks. Otherwise you could try hunting ebay or craigslist to find a replacement, or use some electrical tape to hold it in place that it works.
May 13, 2011 | Toshiba Satellite A505-S6960 Ac Adapter...
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Where can I get a replacement 9.5v 3.0a DC power
You can either call the company where you got the original cord from or you can call someone that installs that in the cars and see if they have the cord.
Jun 30, 2009 | Televison & Video
My laptop stopped charging and i lost battery and now it wont charge at all, even tried a universal charger as well.
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place....
Jun 04, 2008 | Gateway MX6454 Notebook PC
Orion tv power cord
Try your local radio shack. They may have a universal cord that will work
Apr 09, 2008 | Orion1934 19" TV
Durabrand DUR7 Portable DVD Player Logo
352 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
