I need the code to set my tv watch modelF67997 for mitsubish tv and where to push the rt buttons because the watch is old and its no writing on it
  • 2,113 Answers
Can you rephrase the question. It sounds like english is your second language and nothing makes any sense.
Posted on Oct 23, 2013
How to change passward for asus rt-n12 wireless n router
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
May 01, 2014 | ASUS WIRELESS ROUTER |WL-520G - RT...
HOW DO I ADJUST CLOCK ON 2007 HARLEY STREET GLIDE
When you turn off radio w/ off & on button over on rt of screen set will apear press button watch screen on rt, youll see w/ you need to do ...';';'
Aug 29, 2011 | 2008 Harley Davidson FLHX Street Glide
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
I dont know my pass code of my family setting on my console
hey this is what worked for me. take out your hard drive so you dont wipe the memory from it (it is on the side of the xbox It says HDD on it). you do this by pressing the gray button, and sliding it out. then turn on your xbox and go to the system tab then select console settings then system info then enter this LT,RT,X,Y,LB,RB,Y, HOLD LEFT STICK IN and push X,X. There are a few slightly different codes depending on the serial number because my sons xbox has a different code, LT,RT,X,Y,LB,RB,Y,HOLD LEFT STICK IN and push Y,Y. also my friends xbox has this code LT,RT,X,Y,LB,RB,D-PAD UP, A,X,A. as you have probably noticed the only difference is the last 4 buttons but if you try a few different combinations you should get it. it can be one of either a D-pad or left stick direction, Left or right stick 'push', or A, B, X or Y i think so just play around it is the only way unless you call microsoft.
hope this helps
Nov 15, 2010 | Video Game Consoles & Games
Need to how to take radio out, for radio code
go to a mitsubishi dealer . they may charge to rest the radio with the code that matches your vin. write the code down as if you change a battery in the future you will need it again.
the numbers for your radio stations are what you set the code with. 1st # is put in using first button 2nd # second button and on like this with all four station buttons then push th the button above to reset. make sure to watch at the dealer.
Apr 20, 2009 | 2000 Mitsubishi Montero Sport
Synergy V rt-u64cp remote to control Receiver volume
For those who want your audio device volume to work without changing modes here's how: hold cable and select until cable lights up - then press volume+ and then press audio. That's it.
Apr 06, 2009 | Televison & Video
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
How to work my wrist watch
I found a solution on how to set the time digitally. what I did was got an old watch of mines that had the four push buttons two on each side and read what the four sides said on the old watch because my new watch didn't have any writing on either four sides. So basically the writing was similiar to how to work my new watch. The left button to the bottom was for the MODE, the upper left button was for the LIGHT, the upper right button was for START, and the lower right button was for RESET. I just worked with these buttons now that I had an idea and was able to set my digital part of the watch with a little effort. I hope that this may help someone who is having the similiar problem that I had.
May 24, 2008 | Watches
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
