Question about Admiral Craft Avantco Conveyor Toaster with 3" Bagel Size Opening 120V
I purchased a used Avantco conveyor toaster from ebay for my restaurant - model #CTA7001 ...the bottom element was not toasting but the top of the bread comes out perfect . I ordered a new element installed it and still only the top of the bread is toasting,,,,I put it on bread toast but it still does not toast the bottom of the bread :( any idea of what the problem could be ?
Conveyor is squealing as soon as toaster heats up. How can I fix it
you cant,somethings you have to deal with if you put anything on it,it will burn off and get on the toast,you could try a drop of peanut oil on each link,but,nothing more
Jul 11, 2015 | Holman QCS2-500 Conveyor Toaster
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
The bread is getting burned at the top but not toasting the bottom half
You need to replace the elements.
Their are in ebay, very good price and they wll arive to you in a couple of days.
You can find istruction how to order and how to replace in this tip
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Aug 08, 2010 | Dualit CTS4E 4-Slice Toaster
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Admiral Craft Avantco Conveyor Toaster with 3" Bagel Size Opening 120V Logo
75 people viewed this question
Top Admiral Craft Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Admiral Craft Kitchen Appliances - Other Expert? Answer questions, earn points and help others
