Question about RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds
Problem J413SV Early Bird clock radio. Please phone Mrs M Billings on 01332552322 after 3.00pm. I have made many unsuccessful attempts to phone you on 08454818808
Tip
How to set the time & alarm for SI564
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} After several unsuccessful attempts to locate a user manual for this clock radio, I discovered for myself how to set the time and the alarm for this model by trial & error. Hope this tip helps others!
Press the MODE button located on the top of the clock. The screen blinks the hour with "AL HOUR?" specified. Press the SELECT button to go forward or the PRESET button to go backward. Press the MODE button again to set the "AL MINUTE?" Subsequent presses of the Mode button scrolls through AL BUZZER, AL VOLUME, HOUR, MINUTE, DUAL HOUR, 12/24 HR, YEAR, MONTH, DATE, temp F or C, AREA features. It seems that the clock saves the last setting you made once you stop pressing any buttons.
on May 29, 2009 | Sharper Image SI564 Clock Radio
Replace clock movement Rising QS228
I have a singing bird clock risingqs228. Is there a replacement part as it is loosing time. Thanks TOM
Jan 17, 2014 | Audio Players & Recorders
Instructions for Proteam Ho 1940 bird sound wall clock
Take out all 3 batteries. Move the hands to 5:50. Put batteries back. Start turning the white dial to correct time. As you're turning, if the clock is silent after 9 o'clock, you are on PM. For am, continue turning white dial to 6 o'clock when the bird sounds will start again and then to the correct AM time.
Jan 06, 2012 | Audio Players & Recorders
I had to purchase a new battery for the car. After installation, the COdE message for the radio would not allow me to play the radio. I attempted to put in the 5 digit code but was unsuccessful. What do...
After two tries, the radio assumes tampering, and stops receiving the unlocking code. Disconnect the battery for 10 minutes or so, and attempt again to introduce the code.
Aug 25, 2010 | 1996 Honda Accord
How do you set the clock on a Dodge Chrysler 600?
bboy its been awhile since Ive seen a 600 but try key on radio on push set and then rotate the tuner knob .I try to refferance some old manuals hope it helps
Jan 01, 2009 | 1985 Dodge 600
Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Mar 17, 2008 | Refrigerators
Singing bird clock
take batteries out set clock to 12.50 pm then insert batteries and set to normal time. this will then put correct bird sounds with relevant bird.
Dec 31, 2007 | Audio Players & Recorders
RCA Alarm Clock w/CD Player, AM/FM Stereo & Nature Sounds Logo
16 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
