Question about Freezers
Kyoto ku88 freezer - Freezers
Given a second hand Kyoto KU88 Freezer, have let it settle; plugged in and on FF, nothing happening - just red light on?
Posted on Mar 15, 2015
Why is my Electrolux freezer outside walls hot
The condensing coils are embedded in the walls of the freezer. The freezer uses the wall as a heat sink. This allows the freezer to dissipate the heat that has been pulled from inside the freezer to the area outside of the freezer.
Jun 15, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Hello, I Have a new freezer. It was installed 16
the freezer will not cycle off until the desired temperature is reached.
Feb 12, 2011 | GE FUF21SVR Upright Freezer
Kenmore fridge over pullout freezer. Freezer has snow. Model 59673502201 . Fridge runs, and shuts off apparently normally. Freezer is cold, air blowing (fan?) from behind freezer temp control. Thought...
Please : - Clean up your freezer - set the thermostat to middle - check the fan for malfunction
There are many things that cause your freezer work abnormally.
Nov 07, 2010 | Kenmore Freezers
My freezer was delivered in a lying down position how long before i can use?
puts the freezer in correct position and the your freezer life is 10-20 years,depends of freezer quality and freezers engine *can increase the freezer life with BEST QUALITY USING
Jul 28, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
Horizontal fridge freezer - Freezer over-heating
The door frame has a heater to stop ice forming around frame. This is normal. You don't notice it when freezer is cold. The freezer should start working again.
Nov 01, 2009 | Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Buzzing noise -Kyoto KU 9577 Freezer
you may have a bad compressor or a bad compressor relay. The buzzing noise sounds like the compressor trying to start but can't. Unplug the unit and pull the relay off the compressor. If it rattles like gravel in side it replace the relay. If it doesn't then you may need to call a repairman to check the compressor. Hope this helps.
Apr 11, 2009 | Freezers
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Freezers Logo
146 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
