Question about Vacuums
Hoover Manual how to clean hoover 9010PH cyclonic vacuum cleaner
SOURCE: Hoover Fusion Cyclonic
Ok, lfitz, I fixed my problem. First I called the Sears Service Center. They told me that I would have to drop it off there, and they would send it to Orlando to get looked at. The whole process would take about 2 weeks and who knows how much money. So I decided to become my own Hoover technician. It turns out that my original diagnosis was right about the chord that electrically connects the power on/off switch at the top of the handle to the rest of the vacuum. This was extremely easy to fix so please don't be scared away, although it does require a little philips-head screwdriver action. As always, make sure the vacuum is unplugged before you start. On the back of the vacuum, there is the hook that you wrap the electrical chord around for storage (the top one). On either side of that hook are two screws. Unscrew those. Now, the small piece of plastic that has the hook on it can be carefully pulled back, or removed if you need to. Inside, I found the detached end of a coiled black electrical chord that looks kind of like an A/C adapter. This chord should be plugged into the bottom of the metal shaft that slides in and out to allow you to adjust the height of the handle. Now, adjust the metal shaft so that you can plug the black chord back into the base. Push the chord in until you hear it click. Now, put the plastic piece back in place and put the screws back in and you're done. Plug it in and give it a try. I hope this helps.
Posted on Dec 16, 2007
  • 46 Answers
SOURCE: LG Cyclone Vacuum Cleaner Model No VKC902H
there is a small belt inside the head ,remove screws and disasemble carefully. and replace /refit belt
Posted on Feb 09, 2008
  • 3 Answers
SOURCE: hoover mach 3 cyclone vacuum
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Posted on Mar 01, 2009
juststinks
  • 98 Answers
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Posted on May 08, 2009
  • 51 Answers
SOURCE: hoover carpet cleaner F7458-900 issue
The pointed valve that is in the tank may need replacing. The two valves are a set. I just ordered some from www.usavacuum.com
Posted on Sep 06, 2009
Why is it my vacuum cleaner keeps shuting off after ten minutes. i have a Hoover wind tunnel uh70086
Sounds like it has an overheat problem and is shutting down to protect itself. Make sure the exhaust filter is clean and that there are no blockages. Hoover UH70086 WindTunnel Cyclonic Pet Rewind Plus Upright Vacuum Parts...
Sep 17, 2015 | Hoover Vacuums
How to open Hoover S3825
Hi there! We recommend taking your cleaner in to a Hoover authorized service center to have the motor replaced or repaired. I have included a link to the service center locator if needed. Hope this helps!
Service Center Locator
Oct 05, 2014 | Hoover Elite Cyclonic Canister Vacuum with...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
It shut off and will not restart
All the filters have to be removed and cleaned or replaced
Apr 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover mac3 cyclonic
check the owner's manual, clean ALL the filters, check for hose clogs.
Oct 16, 2007 | Dyson DC14 Full Access Bagless Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
