Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at shaversource.com. See link below for product and helpful disassembly video
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at shaveroutlet.com. You can order which you require. See links below
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
I followed the instructions from Nick123456 for taking the shaver apart, cleaned all areas and oiled everywhere I could see moving parts around the motor. Then I put it back together making sure that the side screws were very tight. It is now much quieter and the shave seems OK but not brilliant. (Sorry about the typos in the original posting).
