Question about Hotpoint Washing Machines
Hotpoint aquarius wdl540 stops mid cycle and all lights flash
SOURCE: Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
beltronic205
  • 1467 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
reddyanantha
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
active209
  • 14 Answers
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Posted on Nov 06, 2009
How do I find what the problem is with my hotpoint aquarius wdl540
DOES IT AGITATE? CHECK THE DOOR SWITCH, THE MOTOR COUPLER, THE BELT, THE CLUTCH WHICH EVER IS APPLICABLE? DIRECT OR BELT DRIVEN?
Aug 31, 2014 | Hotpoint Washing Machines
My hotpoint wdl540 stops after the rinse cycle and all the function lights flash along with the start/pause light how do we access the inside of the machine to chekc the motor./brushestec
Go to www.repairclinic.com and enter wdl540. With luck, you will be presented with a list of common repair parts and may be able to view a generic Hotpoint disassembly video.
Aug 24, 2017 | Washing Machines
Instruction manual for hotpoint aquarius WDL540 7kg Washer/dryer
My washing machine's indicator flashing after 5 minutes,what should i do?
May 13, 2012 | Washing Machines
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Wdl540 clothes go through drying cycle but come
If there is no heat at all then the heater or the temp sensor or the thermal fuses are defective and need replacing.
Also check that the lint filter is clear of debris and lint. Rinse it if necessary in some mild washing up liquid in warm water and dry thoroughly. Check that the air outlet hose is clear if you have one fitted. Check that the condenser is empty of water and the case is free from dust and lint. Vacuum / brush or wash the outside of the collector in washing up liquid and warm water and dry.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Dec 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
