Xante Ilumina® 502  Laser Printer Logo
A
Anonymous Posted on Oct 22, 2013
Error code 331 - Xante Ilumina® 502 Laser Printer
Fuji Xerox ApeosPort-IV C4430. It has 116-331 fault code error. Any assistance to remove and get it done??
Question edited for clarity.
Power Cycle it.
Fault Code 116-331
Xerox https://www.support.xerox.com > en-us > article
Jan 19, 2021 - Power off/on the printer. For details, refer Power Off the Printer Using the Power Switch. Wait Two Minutes and Then Power On the Printer.
Missing: C4430 ‎' Show results with: C4430
Thread: Error 116-331
Copytechnet https://www.copytechnet.com > ... > Xerox
Jan 20, 2012 - Hi, 1. Check and reset all connectors on ESS PWB and HDD. 2. Press and hold the 4, the Stop, and the Power Save buttons on the Control Panel ...
Xerox workcenter 5225 show error code 116-331
Sep 10, 2019
Dead Machine 242 code 116-331
Sep 10, 2019
WC 6515 Error 116-331
Jun 6, 2019
xerox workcentre 5225 116.331 error code
Sep 6, 2012
More results from www.copytechnet.com Missing: C4430 ‎' Show results with: C4430
Need urgent help with Error Code 116-331! It's a PrimeLink ...
Reddit https://www.reddit.com > Xerox > comments > need_u...
Nov 26, 2022 - 116-331 is usually just a corrupted job. Power off the machine using the button behind the front door. (not the button on top). Press and hold # ...
Xerox Versalink C7025 error code 116-331
This error code could indicate an issue with the drum or fuser. Ensure that the toner cartridge/drum has been seated correctly, and if necessary contact a qualified technician or Xerox support to further investigate and resolve the issue.
Xerox work center5225 error code 116-331
Switch the power off, remove the HD, switch the power on, wait until machine warming up.
Switch the power off, reinstall the HD, and switch the power on.
1helpful
Can't connect mac to ascent avx 331
This is a Windows only product.
1helpful
I need help fax canon B120 error ##331
Hi tamerandaman,
The error ##331 meant that the level of ink cartridge , can not be detected.
Follow the steps to resolve this error
  1. resave the detection level Ink by entering the service mode
  2. replace the ink detector
I hope the issue should get resolved. Please dont forget to rate me. Thanks in advance. Have a great day.....
1helpful
Error ##331 of cannon fax B120
the error code ##331, means that the ink level can not be detected it can be a problem of ink level detector; you need to resave your ink level. to resave the ink level: look at this link: http://www.fixya.com/support/r6643185-waste_ink_tank_full_fax_b120_b140_b820 if you need a clarification you have to add a comment to this solution.
8helpful
ERROR ##331
The level of ink cartridge , can not be detected Solution :
Top Xante Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
