Question about Cell Phones
I lost my manual for the power pod360. I can't get it to work for me. Does anyone know how I am suppose to recharge it or make it work?
My Power POD360 speaker the usb port came loose inside the unit. Can I take it a part and fix it?
Yes it can be done if you have tools and the knowhow. If not take to a computer repair shop.
Oct 13, 2014 | GPS
Key is not working
Nice looking safe. You can download an owner's manual from sentrysafe.com.
Some safes have provisions for supplying power to the combo in event of battery failure.
I don't know how it is supposed to operate with key.
Jul 31, 2009 | Sentry Fireproof Safe
When plugged in, the ipod batteries go low immediately.
The JBL On Stage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adapter. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adapter. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried this on different versions of the iPod nano and this seems to work.
Apr 16, 2009 | JBL On Stage Micro Portable Speaker Dock...
Citizen Eco Drive watch
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, did you store your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Mar 05, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Charging my camera
No, the camera does not recharge via USB.
Look for a manual at http://support.nikontech.com/app/answers/detail/a_id/13948
Aug 24, 2008 | Nikon COOLPIX P4 Digital Camera
How recharge battery of mintek mdp1020
leave battery attached to dvd player and plug dvd player in. leave dvd player off. LED on front of unit should glow orange. When it turns off the battery is fully charged
Feb 08, 2008 | Mintek MDP-1020 Portable DVD Player
Lose time and date stamp on power off
According to the manual, you need to power up your 710 with the AC adapter for 4 hours to recharge the internal battery. If this doesn't work, I suppose you need to replace the internal battery, and that's beyond my knowledge.
Sep 07, 2006 | Panasonic PV-DV710 Camcorder
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
