Monitors
Problem for Monitors
Generic problem for all Monitors
Desktop screen is stretched abnormally
By Nauvice on Apr 26, 2009
hi all,
i hav samsung samtron 45bn monitor, the desktop screen is abnormally stretched lengthwise. i tried to fix it wid control buttons on the monitor but of no use.
wht shud i do?
Nauseating mal-adjusted aspect ratio on widescreen monitor, Samsung. No manual. Stretch is so bad I can barely read posts to find help.
Pls can someone explain step-by-step how to adjust this? TIA
Solution #1
posted on Apr 26, 2009
Somewhat Helpful)
whitebirch
Rank: Guru
Rating: 86%, 310 votes
Here we go...go to an open are on your DESKTOP->PROPERTIES->SETTINGS->SCREEN RESOLUTION->SLIDE IT TO 1024X768->APPLY->OK
close and reboot...
now if it is better but not exactly what you like repeat the process and choose another setting one to the right...and see if you like it better.
If only your desktop is out of proportion then that is a little different:
again right click in an open area, properties, desk top, Position,
use the drop down arrow and choose center...apply and then OK
and that will fix that..
hope this helps my friend, good luck, please leave rating...
thank you kindly
Was this helpful?
Yes
No
Solution #2
Not Rated)
NitrusInc
Rank: Guru
Rating: 87%, 178 votes
Heres how to change you screen resolution in Vista:
http://www.worldstart.com/tips/tips.php/64
And here for XP:
http://www.microsoft.com/enable/training/windowsxp/screenresolution.aspx
Due to the fact that your device has a Wide-screen monitor. you will have to choose the sizes in between the standard ratio. Here's list depending on if your device is 16:9 or 16:10 as well as standard ratio's:
http://www.freakygaming.com/tutorials/4_3_and_widescreen_resolution_lists.html
Hope this information was helpful.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
windows can run but linux cannot run what can i do now.
Answer
Samsung syncmaster 960BG is always black, but windows program starting normaly. what is the problem... (More)
Answer
do you have a vga cable color code for NEC DV15A3 crt monitor
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
