How do I refill the cartridge of sharp AL-2020 with toner
2 Suggested Answers
SOURCE: How to refill Canon FX3 Laser Toner Cartridge
I drilled the hole on the side with no handle. I put packing tape over the hole and it worked fine. I'm refilling it again right now... Good luck, have fun, and save some $$$!
Posted on Sep 17, 2008
Sharp AL-2020 - Copier Producing Copies with Faint portions at Top Middle and Bottom of Page
This if often a faulty toner issue. If you are refilling it might be time for a replacement carrier. Alternatively have you checked your transfer belt for areas of damage
Jun 30, 2014 | Sharp SF 2020 Copier
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
The red tringle light is on. What is wrong?
This triangle means that the toner supply is needed. It comes first as a steady triangle meaning toner is running low and eventually flashing triangle which means toner is completely empty and copy cannot run. There are two methods of replacing toner ;
Refilling and cartridge replacing.
  • You can refill by opening the waste container and then removing the lid on the unit. Use a sprout provided in Sharp Al1000 toner bottle or improvise by folding a paper into a funnel shape.
  • For cartridge , pullout the old cartridge and replace with a Sharp Al100td cartridge.
Nice time.
Dec 10, 2010 | Sharp AL 1631 Copier
I have a red triangle flashing and the copier sounds like it is trying to warm up and then does nothing. what is going on?
Hi, this triangle means that the toner is empty. This can also be caused by a defective developer unit drive gears. Check that it is okay if not replace the gears. Replace the toner cartridge or refill the toner in its unit. Make sure you empty the waste on its side as it may cause some noise or toner spills. Use cartridge Sharp Al100td or refill with Sharp Al1000 toner bottle. All the best.
Nov 23, 2010 | Sharp AL 1631 Copier
Red LED's on Sharp AL 1010 shaped like bowling pins
This is your out of toner indicator. I describe them as a stack of 6 dots. In any case you will need to buy a new toner cartridge or have your current cartridge refilled.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1010 Copier
I have a SHARP al-1661cs copier/printer. i keep getting a "replace TD cartridge" message. I have replaced the cartridge and it still come on every couple of days. i take the cartridge out, shake it and the...
Are you having your cartridges refilled?
By "replace TD cartridge" message do you mean the little stack of 6 red dots on the control panel?
The sensor for this condition is contained within the toner cartridge. The sensor reads the mixture of developer to toner ratio and tells the machine to add toner when needed. If you are having this problem with 3 different toner cartridges then I would suspect the toner add drive system. If you are having just the 1 cartridge refilled and have had the problem with the last 3 refills then the cartridge itself may be the problem.
I'll let you repond then we will see if further info is required.
Mar 29, 2010 | Sharp AL-1661CS Laser Digital Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
My Sharp AL 1000 has quit copying!
The triangle or stack of 6 dots is the toner cartridge light. The drum light looks like a cylinder or aa battery.
If you open the right side door, then the front door you will see the 2 cartridges. The toner cartridge is on the left and should have a large green button you push down on to release and slide out. Later or when needed you can slide out the drum cartridge AFTER you remove the toner.
You might have a local source to get your toner cartridge refilled. Or just order a new one and unpack it, then slide it in and your all set.
About $50 for refill or about $100 for new.
Good Luck
Nov 25, 2009 | Sharp AL-1000 Copier
Copier won't print after refilling toner cartridge
As far as I know, filling up with toner is not enough. There is an electronic chip that must also be replaced, so the toner cartridge tells the unit it is a new one. Check with your supplier for such chip.
Oct 14, 2008 | Sharp AL 1631 Copier
Replace toner
Dear sir,
Commonly the sharp and toshiba toners are normally sealed units, therefore no toner refill avaibable.
Contact your service outlet to order a new toner cartridge
May 09, 2008 | Sharp AL 1631 Copier
35 people viewed this question
jasbo
jasbo
