Question about Samsung Ht-e6730w 7.1 3d Ready Blu-ray Home Theater System W Wifi Hte6730w
HT D6750WK/XS I connected a HDMI cable from Set-Top Box out to Blu-Ray HDMI 1 (IN). I connected a HDMI(with Audio Return Channel) (out) from my Blu-Ray to my Samsung HDTV HDMI 2(ARC). Everything works fine. The HDTV clarity and the sound clarity, Problem is when I switch on the Blu-Ray and the set-top box to on, I have to toggle a few times on the HDTV remote to get picture. This is troublesome. Is there a better way please. Thank You. George Martin Singapore HP: 96264072
Agent Jason
  • 78 Answers
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Go Ahead. Use Us.
Posted on Jul 23, 2008
  • 20 Answers
SOURCE: Samsung HT-TQ85 HDMI Input not working
I rember reading an article stating that the HDMI does not suppory audio
Posted on Sep 23, 2008
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
Posted on Nov 06, 2008
  • 12 Answers
SOURCE: No Sound on Samsung HDTV? But there is a picture...?
have you tried to umplugging the tv and let it sit for a little while. I would unplug the tv like before you go to bed and plug it back in in the morning and try it
Posted on Nov 18, 2009
Testimonial: "Well, I unplugged it for several minutes, and that was enough... thank you very much!"
SOURCE: samsung LED UE46B7020 tv wont play sound through my HT-C5500
press the top right hand button on the remote for the ht-c5500 untill its display reads "D.IN" (Digital Input)
Posted on Jun 30, 2010
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
Jun 14, 2016 | Hitachi Televison & Video
My Blu-ray DVD MBFH does not work on my Blu-ray player
do you have it hooked up via hdmi to a tv that has hdmi? also make sure you set the output for the dvd/blu ray player to the correct output your using (hdmi 1 or w/e not a passthru or input) also if your using component cables you may have to go to menu on the unit and select that as your outpput get back to me let me now if this helped
Mar 17, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Amp freezes when tv channel is changed
Are you using the HDMI for video AND audio or just video? Are you using the reciever as the video switcher by routing your devices into the amp and then from the out of the amp to the TV and then back to the amp from the TV HDMI output and the digital output? You may have a loop going on and the amp can't handle it.
If you are coming out of the TV with both HDMI and digital hooked to the same input selection on the amp and have the amp set for auto signal select, it could be throwing the amp for a loop and causing it to freak. From what I can see in the specs for that amp it has 2 HDMI in for connecting a HiDef Sat/Cable box, a DVD or Blu-Ray player or a gaming console, and then 1 output to the TV. HDMI handles both audio and video. Disconnect the digital cable and just use the HDMI for both audio and video.
The optimal set up would be as follows:
With a cable or sat box with HDMI out, go to the HDMI input to the TV. From the TV use either HDMI OR digital to the amp, not both. If you have Blu-Ray or HDMI DVD, connect that to the other HDMI input on the TV.
If the TV has only 1 HDMI input then connect the Cable or Sat box to one of the amp HDMI inputs and the Blu-Ray/DVD to the other and then from the HDMI out to the HDMI in to the TV with NO audio cable from the TV to the amp. Then use the cable remote to change channels.
See if one of those connection maps works for you.
If you need more help, let me know. Include the TV model and the digital audio cable interface type, whether it is optical or coax. It would also help knowing if you are using a Satellite or Cable box and which one it is.
Jan 03, 2009 | Yamaha HTR-6130 Receiver
What is the best audio configuration with this setup?
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
Mar 12, 2017 | Onkyo HT-S5100 Theater System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung Ht-e6730w 7.1 3d Ready Blu-ray Home Theater System W Wifi Hte6730w Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
