Question about Hoover Dryers
Hoover vhc 680c no heat - Hoover Dryers
3 Suggested Answers
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
  • 3074 Answers
SOURCE: my belt has broken on
you will need to open the dryer up:
http://www.partselect.com/dryer+open-cabinet+repair.htm
and make sure the belt is routed correctly:
http://www.applianceaid.com/images/belt-config.JPG
Posted on Jan 11, 2011
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
My Hoover VHC 381
Unplug the machine and take the top off, check the door switch to see if it is broken or bad.
Jul 23, 2013 | Hoover Dryers
My hoover vision hd vhc 781 xtb is not heating up
if its not heating on any program the heater element has gone but if its still working fine just use heating from you taps to fill to requires temp or disconect from cold and put it onto the hot out let from your piping just remember not to have it boiling as your clother will shring lol
Sep 24, 2012 | Washing Machines
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
My belt has broken on my hoover vhc 392t and im not sure how to replace it
Jan 11, 2011 | Hoover Dryers
Dryers Logo
282 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
