I can no longer pair my ipod to my audiosonic GT001 speaker
Can I pair my jam wireless speaker with my IPod Nano 7th generation?
no because the speaker wont connect or show on any ipods except forr the ipod touch
Feb 17, 2015 | Hmdx Jam Plus Wireless Speaker for Most...
I need an audiosonic hdtd601 user maual. the one that came with teh product does not give any information on using the pvr function
http://www.audiosonic.manuals-in-pdf.com...
ns2.essentialworkspace.com/results.php?...AUDIOSONIC%20HDTD601...
Jul 06, 2014 | JC Whitney - Audiosonic 3-way Custom-fit...
Digix BT-100 Portable Bluetooth Wireless Speaker says not connected when I try to pair it with my ipod.
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
Nov 07, 2013 | Digix BT-100 Portable Bluetooth Wireless...
TDV-98FB4 audiosonic portable dvd player picture
After some experimenting, I have found that the TDV-98FB4 player will play files from USB if they are encoded using MediaCoder and the video output is set to MPEG-4 inside an mp4 container, or if the video output is xvid inside an avi container.
Oct 21, 2013 | JC Whitney - Audiosonic 3-way Custom-fit...
How to connect audiosonic bluetooth speaker car kit to mobile phone?
this is for the little audiosonic hands free car kit that you get from kmart for 7 dollars : you need to hold the on button for 6 seconds then you should see the light flashing blue and red once this is done select it on your mobile and away you go
The manual tells people to pair it another way which is incorrect this will work as ive done it several times to many devices
Nov 24, 2012 | Cell Phones
How do you pair the 903 headset with my ipod touch?
To pair the Plantronics BackBeat 903 with an iPod Touch:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the iPod Touch:
In Settings, choose General, Bluetooth, and turn Bluetooth on.
Choose the device on iPod Touch, then enter the PIN/Passkey 0000 (4 zeros).
After pairing the 903 and iPod Touch, the headset model may appear on the screen when you are viewing the audio or video playback controls. (You can "tap" to switch to a different audio output, such as the internal speaker)
Aug 17, 2011 | Plantronics BackBeat 903 Bluetooth Headset
The right ear speaker on my ipod ear phones no longer emits sound. Is there anyway to fix this?
If you are handy at repairing electronics, you can splice the white cord open and re-solder the wire if it is loose. However I NEVER use the iPod earphones - reason being is when I listen to a song on my iPod and the dial slips past 80% then speakers usually blow. I would buy a pair of Skullcandies, I have 2 pairs and they have never blown. They are only $14.99 at any Target/Walmart and you can definitely save yourself the hassle. Those earphones brand new at stores such as Radioshack are about $29.99, and are very mediocre.
Jun 01, 2010 | Apple iPod Earphones (MA662GB) Earphone ...
I have a 51cm Audiosonic TV with the locked symbol the screen is black
go to directwebsales.com.au and download the user manual.
Otherwise just hold down the f button and press mute.
Cheers
Jul 19, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
Open Questions:
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
