Question about OKI C3400n Laser Printer
Intec edge 850 reset toner chip - OKI C3400n Laser Printer
How inaficho sp 5200dn lock toner chip ?
this printer cartridge has an ID chip. If you want to refill toner cartridge, you will have to by toner and you can buy chip or if you have chip reseter, then reset the chip. It works fine. I use toner from supplier named "Uninet".
P.S. This cartridge is not easy for recycling
Jun 11, 2014 | Ricoh Aficio SP 5200DN - Printer - B/W -...
Toner reset for konica pagepro 1500w
some cartridge have electronic chips on them if the chip says empty then the copier say ok replace the toner will not tell the chip it is new
Jan 25, 2014 | Konica Minolta PagePro Office Equipment &...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Chip intec
this company sells refills and chips
http://www.zinetic.co.uk/CP_2020-list.aspx
Sep 27, 2012 | Office Equipment & Supplies
Problem is replese toner
it was usually happen after you refill the toner.
that is not problem with your replace. but it's must to reset the Chip of toner or cartridge.
or you must buy a new chip.
May 28, 2011 | Samsung ML-2851ND Laser Printer
Samsung printers Messega toner echausted
My printer 4300, when I toner riflling, after i got massage-Replace toner or toner echausted how can i solve my poblem?
Apr 08, 2010 | Samsung SCX-4300 Monochrome Laser...
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
Toner Cart chip reset for Ricoh Aficeo sp c400dn
I believe you will need to purchase and install a reset chip. You can find them for the Ricoh C410 here at www.cfriends.com (that links straight tothe ricoh page - but if you need to search, type in "c410" into the search field on their site).
Jan 03, 2009 | Ricoh Aficio SP C410DN Laser Printer
Toner empty error while toner is not empty, cannot print any document, system data can be print through the printer
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
Dec 04, 2007 | Samsung SCX 4200 All-In-One Laser Printer
OKI C3400n Laser Printer Logo
53 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
