Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
1996 Chev Diesel shuts off or will not crank, all random events. Computer, os unit has been replaced. and fuel filter replaced. I suspect that it is an electrical issue.
    Novelist:
  • 111 Answers
Might be the problem lies in the starter, if the starter is bad then your vehicle won't crank, If you need more help on how to repair your starter, I would suggest checking out this site How To section http://www.buyautoparts.com/howto/repair-starter.htm
Posted on Oct 23, 2013
1996 406 engine fuel problem
Problem Event Name: BlueScreen
Dec 15, 2013 | 2006 Peugeot 405
My girlfriend owns a 1996/7 (VIN says 1997, but door sticker says 1996. Im assuming late 1996, but a 1997 year model). Recently it started, ran for a few minutes, then died. It has not run since. I have...
ok first answer is the door says a month and date of manufacturer. its a 97. second if you have fuel pressure then you have eliminated the fuel problem. the crank sensor sounds suspect. you said random cyl misfire and that is leading me to the crank sensor. the pickup coil in the distributor could also be suspect. did you change the cap and rotor? ive seen the rotor burn thru and short. doubt if you lost compression all of a sudden.
Jan 20, 2011 | 1996 Dodge Avenger
Died going down road like out of fuel wont crank now fuel pump works turns over wont crank
if no check engine lite -check fuel filter,egr valve,cat converter computer
Feb 16, 2010 | 1999 Ford Super Duty F 550
Have the diesel version 1996 e class. something
With the diesel engines you have to let the ignition coil warm up before you will have any luck cranking it. Diesel cars are no good in subzero temperatures. I had the same problem with my 92 300D Turbo and when i took it to MB they told me it was because i wasnt letting the coils heat up long enough.
Feb 11, 2010 | 1996 Mercedes-Benz E-Class
1996 jeep cherokee shuts off with no warning signs cranks back up and may not do it again for days.always happens when cold. replaced crank sensor; distributor; coil; plugs and wires.need help
Suspect fuel pressure. You could install a fuel pressure guage. There is always a fuel pump cutoff safety switch. It is either in oil pressure switch or alternator connection. But have you changed the fuel filter?
Jan 16, 2010 | 1994 Jeep Grand Cherokee
Diesle engine quits after starting. 6.5 turbo chev
If your filter hasn't been changed recently then by all means do itand see if that helps. I change mine twice a year, spring and fall. You are probably right about the fuel pump but your best bet would be to pick up a copy of Haynes Diesel Engine Repair Manual, part #10330 first. It has an excellent diagnostic and repair section as well as testing procedures and repairs for these engines. It costs about $20 and could save you some money. Hope this helps.
Sep 20, 2009 | 1994 Chevrolet C3500
1995 Chevy Diesel, Randomly dies
Sounds like you have a problem with the crank sensor.They can have an intermitant fault.like an open curcuit Try changing the sensor.good luck hope that was helpfull.
Jul 24, 2009 | 1995 Chevrolet C/K 2500
1996 Plymouth Neon 2.0 installed new timeing belt and now car is only running on two cylinders, in cylinder two a missfire was detected and random multiple cylinder missfire
You have the timing belt off. If the engine computer sees the Crank sensor and the cam sensor don't line up, the engine computer will shut down two injectors. It sounds stupid, but trust me. I have seen this before.
Feb 27, 2009 | 1996 Plymouth Neon
Cars
Try replaceing the injection module on the side of the injection pump.
Oct 14, 2008 | 1996 Chevrolet C/K 2500
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
