Can you show me te shipping bolts up close - Washing Machines
    Sergeant:
    Champion:
  • 257 Answers
What kind the washer is?
If the front load, there are 4 shipping bolt at the back to keep the drum not moving when it comes out of factory.
If the top load, the shipping bolts are normally at the bottom of the basket.
Posted on Oct 23, 2013
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Te display
What about it? Just take the manifold off and fix it. A chisel is the usual tool for taking one out, and replacements are available that tighten with a center bolt.
Apr 12, 2014 | LG WM-2277HW Front Load Washer
When I switch on my acer laptop..., the sounds " te te te te " comes on ... it makes me annoying... what should I do.. pls give me simple answer
go to control panel click on sound click on recording and select your mic from the list and click on properties. click on the levels and slide the microphone boost to starting position. click ok and apply ok close and see the sound still comes.
Dec 02, 2012 | Acer Aspire One PC Notebook
If a front load washer is being shipped with only 3 shipping bolts ( from korea to USA),would the washer be OK or there could be possible damage to the drum/washer in anyway?
3 bolts will be ok, The drum cannot move and as long as the other 3 bolts are intact and not broken then there won't be any damage to the machine.
May 02, 2017 | Samsung WF431ABPXAA Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Door contact shows door ajar
If the door is closed and you still get the door ajar message then chances are the plunger in the door frame is bad. The plunger is the little switch that pushes in when the door closes and opens with te door. you can push it in and out with your finger to test it.
Mar 18, 2010 | 2003 Ford Expedition
Release tension on serpentine belt 97 olds achieva. Do I use the GM tool that has the square head? or the bolt on the tensioner. It is a 3.1 v6 engine.
Te bolt on the tenssioner..
Put the correct size closed end wrench on it.. A long one is best for leverage.. Push the wrench in the direction that would losten the belt.. It does take quite a bit of muscle..
You may want to write down the path of the belt before you loosen it.. When loosened - it can slip off other pullies..
Sep 24, 2009 | 1997 Oldsmobile Achieva
The door is locked, no light on, washer won't run
Is the power cord plugged into a grounded 3 prong outlet?
Plug power cord into a grounded 3 prong outlet.
Are you using an extension cord?
Do not use an extension cord.
Has a household fuse blown, or has a circuit breaker tripped?
Check to see if a household circuit breaker or Ground Fault Circuit Interrupter (GFCI) outlet has tripped. If so, reset the circuit breaker or Ground Fault Circuit Interrupter. If the washer is on a fuse box, check to see if a fuse has blown and replace it, if necessary. If the problem continues to occur, call an electrician.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not operate properly with only one incoming source of water.
Is the water inlet hose kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove the inlet hoses from the washer. Remove any accumulated film or particles. Reinstall hoses, turn on water and check for leaks.
Is the washer in a normal pause in the cycle?
The washer pauses for about 2 minutes during certain cycles. Allow the cycle to continue. Some cycles feature periods of tumbling and soaking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look closed, but may not be latched. Open the door and close firmly.
Are the shipping bolts removed?
All four shipping bolts must be removed from the rear of the washer before you operate the washer. Each unit is shipped from the factory with four bolts, which are designed to protect the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration, error codes and possible machine damage.
Has a cycle been selected, but Start has not been selected and held for 1 second?
Press and hold Start for 1 second.
Is the Control Locked status light on?
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Is the Delay Wash status light on?
Your washer will start after the selected hours of delay are completed.
Was the door left closed after the last cycle?
The washer door must be opened and closed again to start a new cycle. If the door is not opened between cycles, the washer may not start.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet has no power
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Shipping bolt installation
A total of four shipping bolts need to be installed: two longer ones on the bottom and two shorter ones on the top. Each shipping bolt consists of a metal screw inside a plastic cylinder which fits between the washer suspension and the back of the washer cabinet. The metal screw pulls the washer suspension against the plastic cylinder which, in turn, is pulled against the rear cabinet, thereby securing the suspension against the back of the cabinet. The Whirlpool part number is 285955. These bolts can be ordered from various suppliers for $20 - $30. To install these bolts, you will need a 13 mm wrench and a flashlight so you can see where the bolts screw into on the washer suspension.
The procedure is as follows:
1. On the back of the washer, remove the 4 plastic covers over the oblong shipping bolt holes. Carefully pack these covers with the water and drain hoses as they will be needed when the washer is re-installed in its new location.
2. Using the flashlight as a visual aid, look inside the oblong holes and identify the area on the washer suspension into which the shipping bolts screw. It is a white plastic part that is not directly behind the the shipping bolt holes, but is slightly above that level.
3.Look at the shipping bolts. The bolts described above (Part number 285955) have a a plastic arm at one end . This arm must be sawed-off for installation on older machines. You will have to determine whether or not the arm needs to be removed.
4. Starting with the bottom two holes, carefully slide a shipping bolt through the hole toward the front of the machine. Angle the bolt upward toward the screw mating hole, and carefully guide the bolt into the hole. Use the 13 mm wrench to engage the bolt into the mating hole.
5. Make sure that the plastic end of the bolt is closely seated against the back of the washer cabinet. Using the 13 mm wrench, screw in the lower two bolts, but do not tighten at this time.
6. Repeat steps 4 and 5 for the upper two shipping bolts.
7. After the plastic part of all 4 bolts has been firmly seated against the back of the washer cabinet, carefully tighten all 4 bolts.
8. Go to the front of the washer and push on the drum. The drum will rotate but it should not rock. If that is the case, then you are done.
Feb 29, 2008 | Washing Machines
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
