Question about Samsung Galaxy Attain Smartphone
My samsung attain is not responding. it turns on and of by itself when i try to charge it.
  • Samsung Master
  • 922 Answers
Test the power button, most Samsung problem like this are the power button that become loose. You can try it by just sliding your finger gently up and down on the power button.
Posted on Oct 27, 2013
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
What is the most likely reason a Samsung gear 2 neo touchscreen would be unresponsive to turn on and off
If your Samsung Gear 2 Neo refuses to turn on:
1. the first thing I would suspect is a dead battery
2. If it does not showing charging when connected to the charging cradle:
A. it could be either a bad charging cable, wall adapter, cradle, bad battery, or the internal charging connectors.. Do a process of elimination only with OEM Samsung cables and charging adapters.
Note: the Samsung Smartwatch charging cradle is not normally sold in stores, so if you lost it contact Samsung support to get another one [1+(844) 454-5925], or download the Samsung+ app from the Google Play App Store to access Samsung Support contact information
B. If the Smartwatch has been on the shelf for a long time (either in store or not used after a long time) the battery will deplete itself so low that it needs to be trickle charged for 10 hrs or less depending on how dead the battery is.. Rather than being put on it's regular charge adapter for a few. Try inserting the charging cable into a computer USB port instead of into the wall charger adapter (see attached video)
3. If the Smartwatch is on, but won't turn off:
A. it may be a software issue.. Like an app you installed is clashing with another, or maybe an update got corrupted by a bad bandwidth connection.. If this is the case reset the watch and start over.
B. It's possible you have too many things going on and all the RAM memory (the brain) not storage space, has been used up.. Which is a temporary crash, just like when you over load your brain with too much stuff at one time..
Samsung Galaxy Gear not working
Dec 20, 2015 | Samsung Cell Phones
Samsung attain SCH-R-920... Charging the battery
you will have to take the phone to a mobile phone repair shop and get them to replace the port. usually cost around $10.00
May 11, 2013 | Cell Phones
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
My Samsung SL30 Camera, are with the image blurred, and the Lens are stucked inside
The battery requires recharging else a new battery is required to replace a depleted once. Perform a power recharge of the device for several hours to attain full capacity. The camera lense should responde there after.
Jan 29, 2011 | Samsung SL30 Digital Camera
Camera turns itself off
or this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 SAMSUNG
Hope this will help
Thanks
Byron
Sep 25, 2009 | Samsung NV3 Digital Camera
Samsung Tocco touch screen freezes
i've got the same problem with you. my phone wont respond to my commands everytime i charge my phone. sometimes it responds but would respond very slowly as if the interface is lagging. every now and then the phone would freeze and wont respond and wont turn off and only way to turn it off is by removing the battery. anyone else having similar problem? how to fix this?
Aug 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My Samsung SGH-t819 Phone turned itself off, won't come back on.
your battery in your phone is worn out.
go to your local cell phone shop and buy a new one..
charge it up and your set
May 23, 2009 | Samsung SGH-t819 Cellular Phone
Samsung e350e keeps turning itself on and off when charging,not holding charge,is this due to wrong charger(its reads thats its charging but its not),or another fault?Phone recently required from...
yes the particular hardware which charges the battery of cell is bad, also go to samsung service centre then try  to change the battery, and definitely it will work.
Sep 01, 2007 | Samsung SGH-R225m Phone
Samsung Galaxy Attain Smartphone Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
